Lower control arms (suspension NOOB)
I Drive Like A Dick 8≈
Fuck my life
So theres a knocking coming from my suspension as of today, went and had it checked out and I was told the lower ball joints are fucked, like totally completely, about to fall apart, giant black dildo in the ass.... fucked and the guy looked up the part and said I need to replace the whole fucking control arm (540 a piece, but that was his price) and I was looking at it and I thought this looks an awful lot like the ingalls ball joints, maybe thats all I need?
Well if someone could please clarify soon, because my car is out of commission till I get this fixed, that would be hugely appreciated!
BTW the reason this sucked so bad for me is because I just started a new job and have like $60 to my name and don't get paid till this time next month
I believe you can get the ingalls upper arms and then buy the moog lower ball joints. The control arms and lower ball joints are the only things ive had to replace so far in 7 years of having my cl. These seem to be the first thing to go.
I didn't notice you said the lower control arm, the only one i see ingalls makes is the upper one but im not positive on that. This link shows the ingalls parts excelerateperformance sells for our car. http://store.excelerateperformance.c...t/g-50202.aspx
Also this site shows the oem lower arm and has it at $132 each. http://www.hondapartsunlimited.com/i...03&version=2DR SPORT&transmission=KA6MT§ion=CHASSIS&component s=FRONT LOWER ARM&submit=submit
ya ingalls only makes the upper ball joints that I found, and the whole set up from acura of peoria is 13x.xx for two so thats not that bad compared to the other price but....
I just found this on moogs web site
http://www.moog-suspension-parts.com...OG-K9643_3.2CL
I know it says its the lower ball joint but I just want to make sure
Tokin up in
B A N N E D
no such thing as lower ball joints in the lower control arm, they are in the knuckle itself, so you would be getting a whole new knuckle
honda likes replacing ball joints as assembly, but as said you found them with the moog replacements, so yes i would go for that then (aftermarket should make just ball joints for the lowers, only thing is that they have to be pushed out with a press, so basically a shop needs to do the actual pressing part, unless of course you got access to a press though
B A N N E D
as said honda likes assemblies, it be parts 1 and 2 for what you were qouted for
http://www.hondapartsunlimited.com/i...ration=KNUCKLE
even then it seems a bit overpriced though, but it is probably in
moose's money though, so would have to convert it first
![Canada](https://acurazine.com/forums/images/smilies/canada.gif)
Read this man, I replaced my lower ball joints and like Fries said, Acura will try to sell you the entire knuckle but you don't need to do that. Go to autozone and pick up the lower ball joint then remove the knuckle and take it to a machine shop.
I don't know your level of car knowledge because this isn't the easiest job in the world. But the good thing is your lower ball joint is already destroyed so you don't have to worry about ruining it when you go to get the spindle off.
https://acurazine.com/forums/showthr...light=axle+nut
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
ok so just to confirm
All I need is the lower ball joint from moog, then the problem after that is getting it in?
if this is right I'm going to order it up and get a mechanic friend to help me out and do a video DIY on this
Update: FIXED, so bought the ball joints and me and my buddy did all the labour. Getting everything out was easy, the only thing that could have been hard was the axle nut, but he brought his 900 foot pound air gun and it was like butter! Also he works at a shop so he pressed them in himself and that was it, reinstall was super easy and everything is great now.
However I think I will soon need new tie rods, both inner and outer so that kinda sucks but wont be that bad and will hopefully get that done within the month!
marcelft
07-10-2018 06:17 PM
nuldabz
09-03-2015 05:49 PM
