Light 19 = Better performance?
Old Mar 10, 2007 | 10:05 PM
LIPPSTUH's Avatar
Unregistered user
Alright, I already have an eibach drop on my 03 cl-s6 and i'm now looking into rims. so here goes.
17" are oem
18" are for looks and performace
19" looks
so i was thinking, if i get light 19" (a bit lighter than stock), will performance be the same?
Old Mar 12, 2007 | 03:28 AM
LIPPSTUH's Avatar
Unregistered user
bump
Old Mar 23, 2007 | 11:30 PM
damntheman's Avatar
5th Gear
Performance how? Only thing that makes larger wheels give a performance gain is they are typically wider and as such you can use wider tires. If you are thinking about straight line acceleration than the formula you want is the moment of inertia..
moment of inertia = (mass)(radius^2)
for example.. a 17" wheel at 25lbs(Don't know the stock wheel weight) has a moment of inertia of around .53 while a 19" wheel at 22lbs is .58
17" = .4318 meters / 2 = .219(radius)
25 lbs = 11.34kilograms(mass)
.219^2 = .048 x 11.34 = .53
19" = .4826 meters / 2 = .241(radius)
22lbs = 9.98kilograms(mass)
.241^2 = .058 x 9.98 = .58
So, as you can see, to make up for the drastic change in diameter you need to significantly reduce weight to not lose acceleration. In the case of 25lb 17" wheels, you need a 20lb 19" wheel to have roughly the same moment of inertia.
Old Mar 24, 2007 | 09:57 AM
Dirty Type-S's Avatar
B A N N E D
or a 18lb 17in wheel!
and thanks for that bit of info Damntheman. real informative. .didnt know how much MATH was used it stuff haha...
Old Mar 24, 2007 | 11:01 AM
LIPPSTUH's Avatar
Unregistered user
well you can go with low profile tires... and make the radius the same
215/50/17
235/35/19
these are the same in OVERALL radius
i used this: http://www.miata.net/garage/tirecalc.html
Old Mar 24, 2007 | 02:30 PM
HondaVtec21's Avatar
Do you rub with your 19''s at all on the Pro Kit??
Old Mar 24, 2007 | 02:36 PM
LIPPSTUH's Avatar
Unregistered user
i dont have 19, i'm going to have 18 soon...
i started this thread before i bought them though...
but hondavtec21... i'm 99.9% positive you can make 19" not rub with eibach.;. its not that low
Old Mar 24, 2007 | 03:29 PM
Alright, Thats re-assuring...lol...I was nervous that I ordered the wrong springs for what I want to do.
Thanks for your help!!!~
Feb 25, 2020 09:57 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
PortlandRL
Sep 14, 2015 12:01 PM
JnC
Sep 11, 2015 06:06 AM
