Konig Crosshairs Wheels 5x114.3* 18x7.5 45 offset any rubbing with 225/45? (ASAP PLS)
If i go 225/45 18 with 18X7.5 5-114.3 45 wheels will there be any rubbing? and i am going to put KYB GR-2 shocks with h&r sport or tein s tech? ASAP PLS THANK Y'ALL!
i heart latin chicks
I do not know. But before I can answer your question in a timely fassion, I would need to know certain things. Such as:
Are you lowere?
If so, how much are you rated at?
How long have you had your current set up? (over time, springs and struts will settle down)
Do you have a cl-s or cl-p? (an oem weight dif)
What mods have you done?
Have you done any weight reduction?
How much gas will be in your car?
Are you out of alignment?
Is your toe properly configured?
Is your camber properly set up?
What is the offset of the new wheels?
So you have spacers on your wheels?
What psi will your new tires be inflated at?
Do you have any body damage to the fenders; are they pushed in at all?
Are you fat?
Or skinny?
Will you be riding with passangers?
Will you have a picnic one day, and have a trunk full of grill and or cooler?
Will it be summer?
Or winter?
How much to these Konigs weigh?
What brand tire, again?
What is the tread depth?
are the tires new?
Or used?
Are the wheels new?
Or used?
If used, are they bent?
Do you have a bbk?
Is your fender lining hanging down?
Is the A/C running?
You see TX-CL, there is much to be played into here, to just simply answer your question.
Are you lowere?
Are you fat?
Or skinny?
Will it be summer?
Or winter?
are the tires new?
Or used?
Are the wheels new?
Or used?
Do you have a bbk?
Is the A/C running?
DunesCreations
09-09-2015 12:03 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
