koni yellow height adjustable?
Before the mods put this in wheel and suspension leave it here because no one answered it over there. Simple question...I heard the koni yellow can't use the perches to adjust different ride height. If you wan't to you have to grind down the metal piece on the shaft? That don't really make sense. Anyone know for sure?
i know for sure...there are more than one koni yellows sp1 and sp 3 def have ride adjustability the sp3 s which i have have two up from static and two down the sp1's have 1 up 1 down so you can raise or lower your car as much as 1 inch front 3/4's rear
This is the one I have...btw i didnt know there was that many different koni yellow for second gen..http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEAFB%3AIT
The Nuespeed have multiple perches. I think there are 5 of them. The regular koni yellows have two settings. With the new Comptech (ie. Eibach) springs and regular koni yellows when you have them on the lower setting the rear tire is just about tucked in...i couldn't fit a finger in the almost non existant gap. With the higher perch it was over a finger gap...I'm not sure if it is quite two fingers, but I can see the top of the rear tire now!
Jul 16, 2017 07:33 AM
you can use the perches to adjust ride height.
