impact wrench size for tires
Old Jun 12, 2003 | 12:25 PM
johnny_2X's Avatar
Questions for mechanics.........
Is a 5 hp 20 gallon air compressor (150 PSI max and 6.5 scfm@40 psi rating) with a 1/2 impact wrench suitable for removing the lugs for our tires?
If so, what is the size of the socket that I need for the lugs of our stock rims?
Thanks.
Old Jun 12, 2003 | 12:28 PM
Scrib's Avatar
Administrator Alumnus
Don't use an impact wrench on lugs. You can strip the darn lugs if you're not careful. A torque wrench serves you much better and you'll know you're not over or under torquing the lugs.
Just my $0.02...
Old Jun 12, 2003 | 12:34 PM
fender4's Avatar
taking off only,, you still have to break loose the lugs before the airwrench will work,, for install,,, most impacts have a low torque range that can be used AFTER finger started,, torque them at 80 ft lbs. my compressor is similar to yours,, just be carefull,, trust me changing lugs is a major pain,, I have learned the hard way,,
Old Jun 12, 2003 | 12:55 PM
Smitty's Avatar
14mm
Old Jun 12, 2003 | 02:04 PM
Shawn S's Avatar
Re: impact wrench size for tires
That’s the size compressor I have, but like the others have suggested I don’t use it for my wheels.
I use a 1/2” Torque wrench set at 80 Lbs.
Shawn S
Old Jun 12, 2003 | 02:25 PM
soopa's Avatar
The Creator
your much better off using something like this then an air powered impact wrench when it comes to taking off lug nuts:
http://buy.snapon.com/catalog/pro_de...re&dir=catalog
Old Jun 12, 2003 | 07:40 PM
fender4's Avatar
very cool buuuutttt $442.00
Old Jun 12, 2003 | 07:57 PM
soopa's Avatar
The Creator
well thats snap-on dude... everything snap-on is 3 times what u can find elsewhere.
you should be able to find a 18 volt 1/2 impact for like $100-200 at a discount tool place.
Old Jun 12, 2003 | 08:25 PM
Fabvsix's Avatar
Cajun Gumbo Man
Yep, I learned the hard way and stripped one when using the improper tools ! It took 3 days to find the replacement part ! I've decided I'm not rotating the tires on my car ! Too much of a pain ! Esp. when I found out how badly with tires each needed alignment when I got new SO3's !!!!!! The car drove straigt as can be, but they were way off ! Each one for that matter !
Old Jun 12, 2003 | 11:57 PM
DRM600's Avatar
19mm is the correct size
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
coykiam
Sep 11, 2015 03:43 PM
NetGnome
Sep 7, 2015 08:33 PM
