How much drop before alignment needed?
Just wondering as I'm likely going to be installing my Tein Basic coilovers tomorrow. I don't have rear camber kit yet, nor do I feel like forking out an extra bill for an alignment right now.
Is there a certain amount I can drop my car on the Tein's without affecting the camber?
Mine is lowered on Tein SS with no gap and haven't done an alignment it drives straight no pull to either side and no noticeable camber wear on tires mind you I only have about 3000km's on so far.
3G TL/2G MDX Owner
always get an alignment after a drop. you are changing the geometry of your suspension even with a 1 inch drop and much more so with a bigger drop. if you're worried about camber, install a camber kit with the new suspension then get the car aligned. otherwise you'll be eating up tires. your car may go straight, but any amount of toe going out of spec will wear your tires much quicker.
So today when I went to get 'em installed I opened a whole new can of worms. Everything down there was seized. Had to order new LCA bushings, bolts, even the front 2 forks. Acura dealership was closed so I gotta wait till morning to order the parts, drove up the cost like craaazyy.
I'm gonna get the Ingalls rear camber kit, then do the alignment...then rust proof. The CL loves taking a beating on my wallet.
Also got a chance to sneak preview my wheels to come..can't wait till spring time! (no pun intended)
sooo i finally got the tein basics in and i'm loving them. to put it in perspective, whoever previously owned the car had the front oem springs chopped! so my car had this weird face down/ass up look and the ride quality was shiiite. the car feels night and day difference.
also the alignment is still within spec, again probably because i was on chopped springs before so the front didn't actually drop any, only the rears did where i noticed a slight negative camber. not gonna bother with an alignment for now.
Zonian22
Nov 14, 2015 01:20 PM
Zonian22
Sep 2, 2015 08:19 AM
