Help - Fitment Question
Old Jan 24, 2011 | 09:38 AM
nf3d0149ab's Avatar
Question Help - Fitment Question
One of my friends thinks I'll have fitment issues on the new wheels I picked up.
Specs on the rear: 19x10 +43
Can anyone confirm if I'll have issues?
Originally Posted by KnightRyderV
hope that fits. seems like a high offset for such a wide rim. you may have clearance issues on the inside.
Originally Posted by nf3d0149ab
Really? They came off an 8th Gen accord and they clear the BBK on a 3rd Gen TL.
Where do you think I'd have clearance issues?
it would most likely touch against the coilover. but im not sure since the CL is a little different than my car. ask lippstuh.
do you know the specs of your current wheels? u can plug it into the wheel offset calculator i use and see how much it will change both inside and outside
http://www.1010tires.com/WheelOffsetCalculator.asp
My current wheels are:
18x7.5 +45
It says that it'll be 36mm less [Inner Clearance] and 40mm extended [Outer Position].
Thanks.
Old Jan 24, 2011 | 10:04 AM
rondog's Avatar
Former Sponsor
You run a risk of hitting the inside of the suspension shock tower.
Old Jan 24, 2011 | 10:09 AM
nf3d0149ab's Avatar
That's what he was afraid of...
But they came off the 8th Gen Accord and he said he had no problems.
I wonder how different our setups are...
Do you think I'll have to run a spacer?
That's already so wide at being a 10 I'm afraid to run a spacer.
Old Jan 24, 2011 | 11:44 AM
civicdrivr's Avatar
Test fit?
Old Jan 24, 2011 | 08:22 PM
nf3d0149ab's Avatar
Test fit?
No tires...
Old Jan 25, 2011 | 03:39 AM
p.diddy's Avatar
i dont think youll have a problem? i had 19x10 +36 and was as low as i could get my car and had no issues.
Old Jan 25, 2011 | 05:49 AM
nf3d0149ab's Avatar
I expected to not have issues so I hope you're right.
Old Jan 25, 2011 | 07:37 AM
p.diddy's Avatar
the difference between my old wheels and yours is 7mm's. you wont have any issues. i dont know your friends but it sounds like tey dont know the fitment on CL's. worst comes to worse put a 5mm spacer. but im sure it wont come to that. so put your mind at ease.
Old Jan 25, 2011 | 09:56 AM
nf3d0149ab's Avatar
Cool, thanks.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
