Final size question:)
Old Dec 3, 2005 | 08:08 PM
Stealth CL's Avatar
proffesion...axle breaker
ok i think i found the rims i want. just a final reassurance that these are going to fit 01' cl-s. is that bolt pattern going to fit?i know cl-s are 5x114.3, thanx guys.
You are bidding on a brand new set of Rota Wheels. Rota wheels are affordable and always follow the latest trends. Here's some of it's features:
Wheel: D2
Color: Black with Polished Lip
Wheel Size: 17x7.5
Bolt Pattern: 5x114
Offset: 48 offset
Weight: 17 lbs. each
Fits: 05 Subaru STi
JDM SSR Professor style design
Certified by JWL, ISO and VIA
Ask about our wheel and tire packages!
http://i24.photobucket.com/albums/c7...D2INRBLACK.jpg
Old Dec 3, 2005 | 09:49 PM
NSXNEXT's Avatar
Bolt pattern:
Offset:
Width:
UNFORTUNATELY
I believe the problem is going to be with the centerbore. The centerbore is what allows the wheel center to fit around the hub. The 05 STI appears to be around 56 mm. The CL/TL is 70.1 which means you would need it have the centers bored out to 71 mm. A good machien shop could do it, but it will cost you some cash.
Old Dec 3, 2005 | 10:47 PM
Stealth CL's Avatar
that sucks, wow, wasn't expecting that. are you sure? could that bore effect the strength of the wheel at all?
Old Dec 4, 2005 | 02:24 PM
NSXNEXT's Avatar
It has nothing to do with the strength of the wheel. It simply won't fit over the hub on your wheel.
Have you ever removed your wheels? Remember seeing a gold colored cap in the center of the brake rotor? That's the hub. It's ~70 mm in diameter. If you try to put a wheel on that has a center bore less than 70 mm it won't sit properly on the hub.
Old Dec 4, 2005 | 04:53 PM
Osamu's Avatar
i thought the CL/TL was 64mm like most late model hondas
the legend, front of NSX, and front of S2k were 70mm
plus are they SPECIFIALLY for the STi, and not for any other car?
you would think that Rota would make them like 74mm like most aftermarket wheels and use a hubcentric ring?
Old Dec 4, 2005 | 05:50 PM
Osamu's Avatar
actually the rotas probably have too small of a center bore, i couldn't find any exact numbers, but you should probably check that out.
Old Dec 4, 2005 | 06:12 PM
NiteQwill's Avatar
Adventurist.
CL's have a CB of 64.1
Old Dec 4, 2005 | 07:27 PM
Stealth CL's Avatar
um yeah i have no idea if they are made just for sti's, that came off an ebay listing, and i cant even find (the D2 )them on rotas website...... but i would doubt it, rota makes rims for all kinds of hondas and acuras. damn i love those rims, but i dont want to have anything bored out just to fit them.....figures just my luck.
any other options?
vpasla1
Sep 17, 2016 07:24 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
thegipper
Sep 28, 2015 01:01 PM
