Excelerate Performance: XLR8 ISC Coilover Special!!!
Old Sep 19, 2013 | 01:00 PM
Excelerate's Avatar
Former Sponsor
Excelerate Performance is proud to announce a special sale on our XLR8 ISC coilover line for the Acura lineup. We have worked closely with ISC suspension to design coilovers for the Acura TL (2nd, 3rd and 4th gen), TSX (1st and 2nd gen), RSX, and NSX. We have become the exclusive distributor in North America for the Acura models, thus making them XLR8 coilovers manufactured by ISC. So what are ISC coilovers and what are the benefits?
ISC Suspension has been present in Asia and Australia for over 13 years and expanded to the North American market in 2008. With roots in motorsports like Formula Drift, ISC is geared towards the performance enthusiast in mind who demands adjustability and reliability. ISC Suspension North America caters to Japanese and European import performance vehicles, attracting both street car enthusiast and race car enthusiast alike. All customer support, rebuilds and service work is done in house in their USA facility (New Hampshire). With a 5 year warranty surpassing industry standards. Featuring products filled with features and benefits ISC Suspension has a strong presence in today's market.
The N1 coilover can be lowered approximately 3-3.5 inches lower then standard ride height. The spring rates are set up specifically to suit your car and therefore will improve handling and stability dramatically. We can make packages for track/rally/drag and of course street. Our lineup will specifically be designed towards the street/sport customer. However, to offer more flexibility we will offer the option for custom spring rates at no extra charge. This will require extra time.
ISC N1 Coilover
Features:
Damper Adjustment
  • Rebound/Compression adjusted in unison via 32 step adjustment.
Pillowball Uppermount (RSX) or Aluminum Upper Mounts
  • Adjustable camber allows more/less on road track for all conditions (RSX only)
Piston Rod Design
  • Strengthened steel piston rods
  • Meets race/sport standards
Sports Spring
  • Made from high quality SAE9254 steel Dyno tested over 500,000 times on compression inspection with less than 5% deformation.
  • Choose from Street Comfort, Street/Sport or Track/Race (spring rates vary depending on application, for specs check the application guide or ask us when you order, custom spring rates are free). Spring rates are typically as follows for the Acura models: Street Comfort 10/6 Street/Sport 12/8 Track/Race is 14/10.
Ride Height Adjustable
  • Full length height adjustable
  • Pre-load adjustable with separate spring locks
  • High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminum Bracket
  • Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance
  • Specially anodized surface to prevent internal corrosion and surface rust
  • On various models camber can also be adjusted via the bracket as well as the camber tops (RSX only)
Single Cylinder Design
  • Larger cylinder and piston design to advance driving stability and dexterity
Thrust Bearing
  • Improves steering and creates a smoother ride
  • $55 upgrade included for free on all our coilover kits with Macpherson style struts
SO WHAT IS THE SPECIAL SALE?
Excelerate Performance will be offering a free front or rear camber/toe kit with the purchase of every XLR8 ISC coilover kit!!!* This is a $125-$160 value free of charge with your new purchase of XLR8 ISC coilovers. Please specify which camber kit you want in the Customer Comment box when checking out.
So what camber kit will you get? Likely it will be as follows:
2G CL/TL - INGALLS Front Ball Joints or INGALLS Rear Camber/Toe Kit
3G TL - INGALLS Front Ball Joints or INGALLS Rear Camber/Toe Kit
4G TL - INGALLS Front Ball Joints or INGALLS Rear Toe Kit
RSX - INGALLS SmartArm™ Adjustable Rear Link
1G TSX - INGALLS Front Ball Joints or INGALLS Rear Camber/Toe Kit
2G TSX - INGALLS Front Ball Joints or INGALLS Rear Toe Kit
*The brand of camber kit will be at our discretion. Market value on our website is not to exceed $160. Cannot be combined with any other special or coupon.
Old Sep 19, 2013 | 01:15 PM
Excelerate's Avatar
Former Sponsor
I probably should provide the link to where to purchase:
http://store.excelerateperformance.c...s/g-65477.aspx
Old Sep 19, 2013 | 05:08 PM
Acidicheartburn's Avatar
Too bad you didn't hold this sale a month earlier. -_-
Old Oct 8, 2013 | 09:06 PM
turbo-cls's Avatar
Where are these made? What exactly does the 5 year warranty cover? Are the shocks/struts included in the 5 year warranty?
Old Oct 9, 2013 | 09:42 AM
Excelerate's Avatar
Former Sponsor
http://iscsuspension-na.com/warranty/
ISC Warranty
ISC Suspension warranties its products to the original purchaser against defects in workmanship and material.
All ISC Suspension products with the exception of Brakes are covered by a limited 5 year warranty that is NON-TRANSFERABLE. The Warranty is limited to the United States and Canada. Professional installation is recommended with all products to avoid the warranty becoming void due to improper handling and or installation. This limited warranty covers Bolt-on components such as bottom mounts, top hats, camber plates, and shock bodies. It also covers shafts and internals such as seals, fluids, pillow ball mounts, and leaking shocks 2 years from the purchase date. Parts and REBUILD labor are covered under the warranty however shipping is not covered.
ISC Suspension Bolt-on Components: Lower Mounts, Locking Collars, Spring Seats, Spring Gaskets, Top Hats/Camber Plates, and hardware such as studs and bolts. All Hard Parts have a 5 year limited warranty.
ISC Suspension Shafts and Internals: Thrust Bearings, Pillow Balls, Jetting Assemblies, Shaft Seals and O-Rings and O-Rings Seals, Piston Shafts, Shock Absorber Internals; Oil and Fluid & Shock Absorber Gas Leaks. All Consumables carry a 2 year limited warranty.
ISC Suspension’s 5 year Limited Warranty does not apply to the following:
Any products that are used on public roads, highways, and or government maintained roads or non-motorsport roads or tracks.
Any products not purchased through an authorized ISC Suspension dealer. Dealer List can be found here: ISC Suspension Dealers
Any products that show abuse, improper installation, or collision.
Any products that have been altered in any way.
Seized Collars, ISC Suspension recommends using anti-seize on all collars to avoid this.
Old Oct 9, 2013 | 11:32 AM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
That little tidbit seems important.
Old Oct 9, 2013 | 03:16 PM
So basically these are only under warranty if you use them SOLELY on a race track? Merde.
Old Oct 10, 2013 | 11:03 AM
Excelerate's Avatar
Former Sponsor
It's a 5 year warranty. The exception is if you damaged the shock. If it's a manufacturer defect they will warranty it. Call them directly if you want to confirm.
No. You can use them on the street or track and still have the warranty.
Old Oct 12, 2013 | 06:55 PM
Chad05TL's Avatar
Wouldn't a manufacturer defect be there from the time we received the damper? What if nothing happens for 1 year, and then there is an issue with road use.. How do you determine if it is a MFG defect or the fact that we drove it on a road? B'cause I guarantee you I am going to drive it on the road. It's my car. Duh! Something sounds fishy. But I do like the fact there is street comfort springs.. I guess we cant use the street comfort springs ON THE STREET!! Go figure! Is this Hilarious or what!
Old Oct 14, 2013 | 11:33 AM
Excelerate's Avatar
Former Sponsor
No, parts fail over time and if it's a manufacturer defect you would get a new damper. Customer damage would be if you scratched the shaft of the shock or a rock kicked up and damaged the shaft.
Old Oct 18, 2013 | 07:27 PM
turbo-cls's Avatar
So where are these made? Didn't see any info on that in your reply or their website.
Old Oct 21, 2013 | 04:35 PM
Excelerate's Avatar
Former Sponsor
Here is the link to the manufacturer's website.
http://www.iscsuspension.com/
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
