clarification needed on tein basic coilover damper kit
Old Sep 23, 2007 | 09:29 PM
CL-S_undance Gold's Avatar
.so i can enevr get it straiight as to whats need for a suspension alteration. i have read about both coilovers and srpings, andhave decided on coilovers for their multi ride height capabilities. so
if i was to get a "Tein Basic Coilover Damper Kit Acura CL V6 2-Dr 3.2L 2001-UP" and install it and get an alignment is that all i need to get my car dropped? i have an 01 type s all stock. -do i need camber kits or control arm or sway bars if i dont have rims??
sub questions, i believe if i read correct the basics allow you to lower it 3.3 inches in front and 2.5 inches in back. is that right?
thanks
Old Sep 23, 2007 | 10:24 PM
o1s's Avatar
o1s
you won't know if you need a camber kit until you have the coilovers installed and set at the ride height that you like. i didn't need a camber kit for mine because i wanted a little neg. camber, others have needed it though.
Old Sep 24, 2007 | 12:32 AM
LIPPSTUH's Avatar
Unregistered user
but camber will result in uneven wear to the tires...
usually people who are dropped on springs need the rear.. but o1s is right..
Old Sep 24, 2007 | 06:37 PM
thanks. what exactly is camber?how the tires stand ...like this......: /\ ll ??
how will i be able to tell? tire wear?
o1s-what about negative ca,ber do you like, i dont reallly know what that means? handling?looks?feel?ridecomfort?
thanks a lot-
Old Sep 24, 2007 | 09:37 PM
o1s's Avatar
o1s
yes, your description of neg. camber is correct. i like it for the handling. when i had stock camber settings, my car oversteered around corners. with just the -1 degree of camber it has helped correct most of it. there is still a little oversteer but i kind of like it.
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
handsom-hustla
Nov 13, 2015 05:04 PM
nanos
Nov 12, 2015 08:41 PM
wusty23jd
Sep 24, 2015 11:41 AM
nuldabz
Sep 3, 2015 05:49 PM
