clarification needed on tein basic coilover damper kit
.so i can enevr get it straiight as to whats need for a suspension alteration. i have read about both coilovers and srpings, andhave decided on coilovers for their multi ride height capabilities. so
if i was to get a "Tein Basic Coilover Damper Kit Acura CL V6 2-Dr 3.2L 2001-UP" and install it and get an alignment is that all i need to get my car dropped? i have an 01 type s all stock. -do i need camber kits or control arm or sway bars if i dont have rims??
sub questions, i believe if i read correct the basics allow you to lower it 3.3 inches in front and 2.5 inches in back. is that right?
thanks
thanks
you won't know if you need a camber kit until you have the coilovers installed and set at the ride height that you like. i didn't need a camber kit for mine because i wanted a little neg. camber, others have needed it though.
thanks. what exactly is camber?how the tires stand ...like this......: /\ ll ??
how will i be able to tell? tire wear?
o1s-what about negative ca,ber do you like, i dont reallly know what that means? handling?looks?feel?ridecomfort?
thanks a lot-
thanks a lot-
yes, your description of neg. camber is correct. i like it for the handling. when i had stock camber settings, my car oversteered around corners. with just the -1 degree of camber it has helped correct most of it. there is still a little oversteer but i kind of like it.
Joseph Stansbury
34
12-04-2015 01:57 PM
handsom-hustla
11-13-2015 05:04 PM
nanos
11-12-2015 08:41 PM
wusty23jd
09-24-2015 11:41 AM
nuldabz
09-03-2015 05:49 PM
