Axis Milano's?
Axis Milano's?
Just wondering if the Axis Milano's would fit on 03 CLS. I did look up the size and they are a 19x8.5 which i believe is a little to wide. Just want to hear some experienced input
Now, is there any chance that they have wheels that are not drilled that you can have custom done to the offset that you need. When I bought the Mod Sevens, it's stamped with an ET35 on the inside. They shave the back down to a 45 and then drill the holes. Maybe if you can get them blank, you can have them shaved to about a 48 and then the lug holes drilled. Maybe it can be done. if you really like the wheels, maybe it's worth asking.
Originally Posted by 6MTpromises
The highest offset for both the Milanos and Crux are +45
Originally Posted by demolition_x
the ones boku had were 19x18.5 with a 45 offset. they don't make these any more.
so if you can find a set they will work fine with a 225 tire.
your answer lies in the last post
https://acurazine.com/forums/ramblings-12/absinthe-131167/
thats if the cl and tl are identicle in that way.
Originally Posted by muddyduck
offset is +45 w/235 35 19 with eibach pro kit springs.
why would your cars value depreciate? its nothing visual or structural. its just excess plastic that pokes into the wheelwell
care to explain?
care to explain?
still cant understand why any one would care.
its like putting in new speakers, you can;t really tell unless you look behind the door panels.
so are they gonna deduct from my trade in because i had to cut the doors to get the speakers to fit?
I have a 03 CLS with 19 X 8.5 with 40 offset and 235/35 tires. My car is lowered with a finger gap, the bumber tabs were cut and fenders were rolled. It rubs a tiny bit on hard bumps, but nothing to make me raise the car up a little more. If you are looking for a really aggressive look, then this set up is what you want or higher. Hope this helps!
Originally Posted by rog2961
damn 19x 8.5 +40???? i have 18x8 +38 and i rub on stock height ive been wondering if it would be worth it to roll my fenders cause i didnt know if the rubbing would go away.
+40 w/ cut tabs and rolled fenders is a much lower offset than what I've seen anyone else run, considering stock is like +50 or so.
My wheels are getting polished right now, I'll post pictures when I get them back, hopefully soon!. What sucks is that I had the wheels on for only a couple of weeks, took them off and dropped them off at the shop. THe guy has had them for 3 weeks now and have a feeling he hasnt touched them yet!
