Anyone interested in bilstein/H&R setup?
OG 3.x^7 rawr
Not sure where this post would belong, but if this is not in the correct area please move...thanks MODS
Well, it looks like I may be ditching my current set-up for a full coilovers. Just want to see if anyone would be interested in my current set-up.
-Bilstein Sport shocks
-H&R Sport springs (51858)
I paid $746.94 for shocks and springs. I had them installed Early last year and have about 20k miles on them. Would asking $500 be too much?
Thanks,
Eddie
Thanks,
Eddie
OG 3.x^7 rawr
It sits perfect IMO...not slammed but a small gap. The ride is awsome compaired to OEM. It feels tighter around turns and a bit stiffer, but still maintains the luxury ride. The reason on switching to coilovers is because I want to adjust ride height and well as dampening. When I take it to Auto-X I want it to be stiff, but when i'm daily driving I want something intermediate.
Well, This is how it currently sits on this set-up....
3.5 psi
I highly doubt you need a camber kit with H&R sports. Not low enough. You can even get away without one with the eibach prokit, which is lower. I really like the H&R sport drop...looking for some 50103s.
OP: If you're looking for stiffness, why not just upgrade your shocks to koni yellows or Tokico illuminas. They have dampening adjustment. 5 settings i think. And when you're on the stiffest setting, you're around 0.8" lower.
OG 3.x^7 rawr
Originally Posted by zac
Did this setup require camber kits?
Originally Posted by TheDonks_03CL
BTW your car looks amazing! GOODJOB!
OG 3.x^7 rawr
Quote:
Originally posted by gnuts:
OP: If you're looking for stiffness, why not just upgrade your shocks to koni yellows or Tokico illuminas. They have dampening adjustment. 5 settings i think. And when you're on the stiffest setting, you're around 0.8" lower.[/QUOTE]
Hmm, I've had Illuminas and Yellows and the stiffness setting did not affect the height. Is this something new? However, I do recall that the Koni Yellows had three spring perch heights that you set upon install, but the difference between middle and lower perch was about 1/4" at most. The Illumina has 5 settings of rebound stiffness and the Konis are continuously adjustable/no detents.
OG 3.x^7 rawr
Stiffness(dampening/rebound) does not have anything to do with height.... Koni yellows do have teh 3 perch setting but like you said it doesn't do too much.......
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
