245-45 18 fit? help appreciated!
Old 06-16-2013 | 10:40 PM
ndz613's Avatar
buying new 18" rims tomorrow wrapped in 245-45 18's just want to make sure they will fit no problem under my stock suspension 01 CLS! Thank you in advance!
Old 06-17-2013 | 07:57 PM
OperationDarkie's Avatar
Ultra Negro
Size of the wheel would be helpful.
mikebikelife (06-17-2013)
Old 06-17-2013 | 11:25 PM
mikebikelife's Avatar
@Mikeshlong On IG
Old 07-03-2013 | 11:36 PM
Anicra's Avatar
Only know the tire specs
Believe you are gaining 1.2 inch in diameter. 245 40 18 would have been 25.7 vs stock 25.5 or 235 40 18 is 25.4. I could be wrong a bit tired. 18x8s would fit either tire well.
Not sure how or if it fits CL 2001. Own the same vehicle.
Leaning towards a no go 245 45 18 based upon rubbing comments on https://acurazine.com/forums/2g-cl-tires-wheels-suspension-54/tire-size-18x8-888217/ thread.
Old 07-06-2013 | 08:13 AM
brian6speed's Avatar
Lone Wolf
Wheel size and offset also matter.
I am running a 255/35/18 on a 18x8.5 +52 wheel. My setup only has 3mm clearance from the front suspension.
I could go with a 18x8.5 or 18x9 with a +45 offset for slightly better fit.
You can do some calculations on www.1010tires.com website. Use the tire size and wheel offset calculators.
You will probably need to roll rear fenders and grind down or relocate rear bumper tabs.
Old 07-07-2013 | 11:03 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
Even with my 225/40/18 on 18x8 rims with 45 offset still hits in the front over nasty bumps. Or if ur ancy going over a speed bump. Technically it fits but it has its imperfections unfortunately.
I am not rockin any serious camber tho, but my car is no where near dumped to the ground.
I suppose if I went a couple of degrees down it would not hit but I cannot imagine having any bigger tires in their and not having any less problems then that
Old 07-08-2013 | 12:40 AM
Ultra Negro
Leaning towards a no go 245 45 18 based upon rubbing comments on https://acurazine.com/forums/showthread.php?t=888217 thread.
It will fit on a CL with stock suspension, the only time he may rub is when hitting a large bump at a good rate of speed, that will be the only time.
Old 07-08-2013 | 09:02 AM
Lone Wolf
My fronts don't rub at all with 18x8.5 +52 with 255/35/18 with a 1 finger gap. I am using ingalls control arms.
Old 04-26-2016 | 09:46 PM
GroundedCustom's Avatar
GroundeDCustoM
What brand tire you runnin?
I researched that Ron dog did the Pirelli p zero in 255/35/18 on a 48 offset and seemed to be successful. No modifications regarding rolling or cuttin fender/tabs
I was under the assumption pirrelis were the only brand KNOWN to be able to do this as they may run tad on the small size?
mada51589
05-03-2022 09:54 PM
jriv7
05-08-2020 06:50 PM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 01:55 AM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 07:12 PM
wusty23jd
09-24-2015 12:41 PM
Quick Reply: 245-45 18 fit? help appreciated!
