225/45/18 w/45offset rim eibach ProKit; WILL IT RUB??
Hey folks
I own a set of 18's wrapped in 225/45/18 (Nankang NSII tires) I offcourse took them off for the winter and now that its time for warm weather I am about to put the rims back on. However since winter, I have had the "Eibach Prokit springs" installed which has lowered the car a little lower than I expected
but anyway I am nervous that may wheels may now rub at times (but not sure.
Before I go through the hassle of having the rims put back on the car balanced and get an alignment I just thought I'd ask#1 if the 225/45/18 will likely rub with 45 offset (rim). #2 If it rubs how much damage is done to the car suspension or tires #3 Should I skip everything and just go for the a set of 225/40/18's instead of the 225/45/18 although I prefer the added protection of the 225/45's when it comes to bumps and potholes
Any thoughts are appreciated before I waste good time and/or money!!
but anyway I am nervous that may wheels may now rub at times (but not sure. Before I go through the hassle of having the rims put back on the car balanced and get an alignment I just thought I'd ask#1 if the 225/45/18 will likely rub with 45 offset (rim). #2 If it rubs how much damage is done to the car suspension or tires #3 Should I skip everything and just go for the a set of 225/40/18's instead of the 225/45/18 although I prefer the added protection of the 225/45's when it comes to bumps and potholes
I ran the same size tires with a 48 offset on the rims and a 1.8 drop and it never rubbed not even close to rubbing. I agree protection wise its better to run the 225/45/18's because with that size I never bent a rim but with 225/40/18's I bent several rims.
I would go 225/40/18 personally....
I run 235/45/17 with 8 inch wheel, +45 and no rub with the Eibach pro-kit....after an alignment. It comes very close to rubbing but barely makes it.
I'd say put the wheels on yourself, and see if you rub. If so, take em off and do what you gotta do, if not, go get your balanced/aligned, though if you already are aligned and the wheels were balanced when you took em off i don't think it's necessary. I could be wrong, but i dont think putting on new wheels changes alignment.
No it doesn't but i am in need of an alignment period...before and after the wheels were taken off... so i have to get one before i put new tires on..Or I will wear those out badly.
Oh yeah Imma put them on myself; just so i can drive to the wheel/tire spot
and have them put new tires on because i aint gonna be lugging 4 wheels (the stock wheels) to and from. Hell naw...but we shall see what happens I'm hopin all goes well because I am telliin U guys...that even though its only the Prokit drop (conservative drop) that car is sittin pretty low. I wanna be able to have passengers in the back of the car ( or stuff in my trunk) and not have to worry about that bytch rubbin on dips and humps. But I ain't gonna stress over it whateva will be will be..I just don't want to get any skinny as tires but imma do whateve a I gotta do! Thanks for everyone's input and comment regarding this matter.
ADMIN U CAN LOCK THIS UP WHENEVER U FEEL LIKE IT
and have them put new tires on because i aint gonna be lugging 4 wheels (the stock wheels) to and from. Hell naw...but we shall see what happens I'm hopin all goes well because I am telliin U guys...that even though its only the Prokit drop (conservative drop) that car is sittin pretty low. I wanna be able to have passengers in the back of the car ( or stuff in my trunk) and not have to worry about that bytch rubbin on dips and humps. But I ain't gonna stress over it whateva will be will be..I just don't want to get any skinny as tires but imma do whateve a I gotta do! Thanks for everyone's input and comment regarding this matter.ADMIN U CAN LOCK THIS UP WHENEVER U FEEL LIKE IT
they will protect more and they probably won't rub, depending on our drop and trunk load, buuuut, they will look less aggressive, more like 17" since the tires are so inflated.
235/40/18 is great on a 7.5" ewidth, it gives a nice vertical sidewall for pretection and actually matches the stock 215/50/17 overall height best.
Originally Posted by AMGala
LOL right...
Throw a system in the trunk and suddenly it's not such a conservative drop...then again I like to thump harder than most, my shit is heavy.
Originally Posted by korchen
So do you guys think that 18X7.5 +42 with 235/40/18's would be fine as well on an Eibach drop?
emailnatec
29
Sep 28, 2018 04:27 PM
