2002 lexus is300 on cls
GroundeDCustoM
can these 17" rims fit?? im reading aloit about legends rocking them but i think they are bette then the TL wheel.
the offfset is +50 i i think. i heard about the bore, im not to worreid, i wud do that, but the offset is of concern. also tire size, if a 235/45/17 would still fit
2002 is300 rims 17" will fit 03 cls?
Whats up with RDX owners?
How are you not worried about hub bore??? The Lexus wheels have a smaller hub bore, meaning they will not site flush on our hub.
Lexus IS300 - 60.1mm
Acura CL - 64.1mm
As far as offset is concerned, theyre close to stock.
Acura CL - 64.1mm
Would have to get the center bore drilled out to the numbers civic gave above. Once you did that, then you can put the the tire size you want and it will work great. I saw a local member with IS wheels before. Without drilling out the center bore, you will not be able to bolt these on your car.
GroundeDCustoM
Yea exactly,i was aware of the.boreing,wasnt sure bout offsets.
QUOTE=aznboi2424;13420119]Would have to get the center bore drilled out to the numbers civic gave above. Once you did that, then you can put the the tire size you want and it will work great. I saw a local member with IS wheels before. Without drilling out the center bore, you will not be able to bolt these on your car.[/QUOTE]
xsilverhawkx
09-28-2015 06:51 PM
