19" tires
19" tires
hey guys i was wondering on your 19" rims what tire size are you running....because i got 225/40/19 and im rubbing in the back.....do you think if i go with a 245/35/19 the rims would camber more and rub too?????
235/35/19 give you the same diameter as the stock rim.
Check the link.
http://www.miata.net/garage/tirecalc.html
Check the link.
when i make a right or left turn it scrapes the fender in the rear ...the rear has a alittle camber so if i get bigger tires like 235 or 245/35/r19 would the tire rub more and be more on a slant????
and how do you put a picture from my computer so i can show you
Going with a wider tire will just add to your problem. 245's would be almost an extra inch wider than your 225's. Your camber would stay the same. What brand of tires do you have? I have 225/35/19's and I still have a rubbing problem.
Re: 19" tires
are the pics in your comp? if so, just email them to me and I'll post them for you, you have to either sign up for free space on the web or attatch them, but I'll do these first ones for you...
send them here:
rondyvous1@aol.com
send them here:
rondyvous1@aol.com
CostcoFanAUS
Sep 18, 2015 06:05 AM
