18x9 (fronts) & 18x10 (rears)
I'm probably going to be picking up a set of Work VS-XX's tomorrow in gold. The fronts are 9 wide and the rears are 10. Not sure about the offset but I'd imagine in the 20's somewhere.
So how much modifications will it take for these to fit? I'm guessing rolled fenders and negative camber in the rear. Will the fronts work without any modifications?
offset has a big thing to do with fitting them ,
a 9" on the front should be okay with a fender roll , if the offset is 25 up
10 on the rear , alil wide , like i said all depends if you're car is dropped or not.
but on the rear , depending on offset , fender roll & pull maybe .
camber is your best friend when fitting wheels
rolled rear fender, front/rear camber and rear bumper tab relocate.
http://www.flickr.com/photos/58529986@N05/6261540515/http://www.flickr.com/photos/58529986@N05/6261540515/ by http://www.flickr.com/people/58529986@N05/, on Flickr
^yo diddy i think i got the exact same wheels as you. not sure about the offset #'s though since the sticker on the inside is worn out. but yeah these are so nice.
if you don't mind me asking what were your camber specs? and also where did you relocate your bumper tabs?
^yeah that's the thing. i don't wanna stretch the tire too much, what if my tire were to go flat, there's no rubber to protect the lip of my wheels it'd be destroyed so fast. plus the ride quality would be better. what's the widest anyone's gone for tire size in the rear?
3.5 psi
if you're going with a wide rim like a 10" you're going to have to stretch tire, run camber and roll fenders and shave tabs, relocate bumper tabs. That's the game. I rub in the rear and i'm only running 18x8 +35 with no stretched tires, shaved tabs and rolled fenders.
I think someone has done a 10.5 rear.
Hmm tire size not rim width. The reason I'm asking is because the tires in the rear are actually 265/35/18 and the rubber is still fresh. These wheels I bought came off a GS-430, I guess that's why they're so big.
So does 265 stand any chance of fitting? Or should I just go with new rubber. If so, I'm wondering what's the largest tire width I should go on 10 wide wheels with rolled fenders.
Also shave tabs does that mean the lip of the fender that sticks inside the wheel well, like just cut that off so it's straight down? If that makes any sense lol
3.5 psi
what are the offsets on the rims? More then likely you'll want the same tire size that diddy was running.
the lip in the wheel well....that's rolling your fenders. They roll that lip up against the inside of the wheel well. There is a bumper tab you'll have to shave down. Tires will rub that first. Or you might have to relocate it. PM diddy.
the difference with that rsx is that its clearly staggered like that for track usage. myself and others arent trying to gain anything. it purely for looks.
as for tire sizes i ran a 225/40 on my 10. that 265 aint going to work so dont waste your time. you can run 235 depending on the tire company. not all tires sizes fit the same. it varies with each company.
azeezp13 (02-21-2012)
18x9, 18x10's...i say too much work to fit especially if your not quite sure that u wanna roll your fenders to begin with. go with the smaller set. from my experience im tired of rubbing in the rear. im lowered on tein ss about 2" and have 18x8.5 in the rear on a 225/40.
oh yeah and my fenders are rolled and shaved tabs.
Thanks to diddy info, it can be done.
I'm running a 18/9.75 all the way around,
215/40/18 rolled front n back + camber kits and u can pull it off
Ur best bet is to run a 215 anything bigger u might have problems
[QUOTE=Darnell Morris;13850503]Thanks to diddy info, it can be done.
Ur best bet is to run a 215 anything bigger u might have problems[/QUOT
wow but is it with 0 camber all around??????
salemboy19 (06-26-2012)
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
