18" x 8" with 43 offset
They will fit. They will stick out. You will rub with 235-40 tires. You might not with 225-40 tires. I had 18X8's +42 droped on CT springs with 235-40 tires & rubbed on big bumps & with any weight in the car.
Originally Posted by slowman
I'm looking at a set of wheels with the described dimensions. Will they fit under an '03 cls without sticking out the sides?
Originally Posted by xenolite
Has anyone looked into camber to prevent rubbing?
I'm sure it'll help if the tire can tuck under on load.
Xenolite
Xenolite
Well for "worth" I think it depends on what people want. With the additional camber you should be able to corner better. I'm not saying like -2 degrees but like -0.5 or -1. When I got my alignment done I found out that the stock camber setting is 0.0 So I told them I wanted more. Turns out I was maxed out at -0.05 (w/o a camber kit). I ended up lower the car more so I think I got some more camber, and I havn't rubbed at these settings.
Xenolite
Xenolite
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
