Wiper issues with 03 CL-S
Old Jul 8, 2009 | 10:10 PM
3.2VtecTL's Avatar
Exclamation Wiper issues with 03 CL-S
I'm having an issue with my windshield wipers, and haven't found a similar issue from searching....
Whenever I turn on the wiper to the Intermittent, Low, or High speed settings, the wipers will remain on, unless I pull the 30a fuse from the driver side dash panel....
If I use the mist feature, then the wiper will sweep the windshield like normal, and not remain on, however I have to hold down on the switch until its back to the resting position....
What could cause this scenerio? Wiper Relay?, wiper motor issues,? Possible bad switch, however it's physically fine, and functional......???
Thanks for viewing, and hopefully I'll find a fix for this problem!
Old Jul 9, 2009 | 03:18 PM
3.2VtecTL's Avatar
anyone have a clue as to what could be the issue?
Old Jul 10, 2009 | 02:51 PM
H's gray 03 CL type S's Avatar
You need to take it to a dealer cuz you have some electrical gremlins
Old Jul 11, 2009 | 12:38 AM
celynka's Avatar
Sundance Gold in
You probably got some glitch in the switch - it rhymes so it has to be that ...- just kiddin, but seriously I think its steering wheel switch.
Old Jul 14, 2009 | 06:53 PM
3.2VtecTL's Avatar
i'm thinking it may be the switch as well! I'm hoping it is because I have a spare one...I guess I can start with replacing it!
I'm trying to avoid the stealership!
Old Jul 18, 2009 | 06:43 AM
mordor110's Avatar
Nick
Yeah I had something similar not on my CLS6 but my Land Rover and it was the switch. (The wipers wouldn't return to the rest position when I turned them off unless I held the mist switch down)
csmeance
Jan 7, 2026 06:25 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
iRaw
ILX
Sep 18, 2015 12:44 PM
Gary Matthews
Sep 11, 2015 01:21 PM
