Wilwood BBK spacer size???
I have an 03 CLS 6MT. I am installing a Wilwood BBK in a few weeks. I am running stock wheels and tire size and from what I understand I will need wheel spacers to fit the BBK under my stock 17s.
What is the smallest mm wheel spacer I can run to clear the BBK? I dont want to pull the wheels out too far!!!
Im running the RL BBK and I heard that caliper is bigger then the wilwood and I need +10mm ona +50 wheel so that means +15mm. So you might be able to get away with something smaller but I doubt you need anything bigger then 15mm and maybe less
I was told 15mm needed for wilwood and 5mm needed for rotora. That would be for 1 piece packages. i think 2 piece rotors require a lil more space.
I was actually researching bbk's other day. It is one of the only mods I am not sure what I want to get yet, plus Ill prob stick with the legend calipers for awhile.
Hey-
I just put a Wilwood BBK on my car and went through a world of trouble with the fitment. I originally had Ron Jon Servos that had the +50 offset. I was in a bind with my car ended up purchasing two Servos with the +42 offset and putting on an 8mm spacer. Additionally, i ended up changing tires from 235/40/18 to 225/40/18.
Hope that helps. If you have any questions, dont hesitate to message me.
As for replacing every part on my car that's a no lol. I still own a black on black 02 cl-p auto for about 5 years and always wanted a black on black 03 CLS6 once I started to get to know more about the cl's. Well I looked for a clean one for over a year and finally came across one in FL about 3 weeks ago so I bought it and got it shipped here to VA. I bought it just in time because my trans finally went completely out in my 02. I always had a itch to mod my the 02 but I knew the trans was shit so never really did. Now that I finally bought the car I want I have a plan and I will mod it the way I always wanted too. It's not going to be some never ending project because I already have one of those my 92 mustang lol. So now you know ha.
I doubt anyone has the rsx wilwood kit on a cl. If I was gonna go thru figuring out if and what is needed to get rsx to fit I would just get the spoon kit myself.
For me personally I was looking at the rotora 2 piece kit(cheapest I saw was 1600) or the brembo gt kit(2400). I decided it is just to much to pay especially since I recently upgraded brakes and put on legend calipers.
In the future I will either upgrade to a bbk or 2 piece rotors. For 2 piece rotors there are the racing brake ones at 579.99 a pair or the dba 5000 for 692 a pair. They are somewhat pricey at first but when you need to replace you keep the aluminum hat and only replace disk so its cheaper to replace.
Hey-
Sounds like you should just upgrade rotors, pads, lines, and legend calipers or go for the cheaper rl setup? You can get a wilwood 2 piece bbk for well under 1500? I wonder how good quality is then since good 2 piece rotors alone are 580 plus a pair.
Btw a bbkis overkill no matter what you spend on it, and is done for looks.
I find it amusing that ppl will spend 2 grand on wheels just to show off a brand name, but they cheap out and buy $150 chinese headers and cheap out on brakes.
I disagree with that statement. If it were done strictly for looks everyone would have those ebay "bbk" covers. There is a huge difference in stopping power between the 4 piston RL calipers and the stock single piston calipers, not to mention the larger pad area and rotor provide much more bite.
Definitely agree, the stock brake setup on our car is under engineered based on the weight of the car it's unreal. BBK is a better permanent solution to better stopping AND not having to buy stock replacement rotors every 6 months. Better looks are just a bonus (having to buy new wheels or 3g wheels that clear is not) I shouldn't need to be self conscious of how hard i'm braking because I don't want my rotors warping..They shouldn't warp in the first place
Btw a bbk is overkill no matter what you spend on it, and is done for looks.
Maybe you haven't looked up the part number I said for the wilwood kit yet. Here it is at jegs.com cross drilled and slotted with the more expensive red calibers, that price is before my discount...
http://www.jegs.com/i/Wilwood/950/140-7014-DR/10002/-1
Well I bolted the Wilwood kit up the other day and I ended up going with the ichiba 20mm v2 spacers. Keep in mind Im running stock wheels right now. I think the smallest spacer you can get away with on stock wheels would be 18mm. It fills the wheel nicely! I plan on wheels next summer but adding the Comptech SC and all the other power adders I wanted to know my stopping capabilities would be increased as well!
Now my big concern is upgrading the rear brakes! They are due as is so I would like to do something larger for them as well.
ExcelerateRep
10-14-2015 08:20 AM
