Whining Noise
Old 10-21-2016, 08:45 PM
dcbakerphoto's Avatar
Whining Noise
I have an intermittent whining noise, usually in 2nd, 3rd, 4th gear. Comes and goes. Can hear it when accelerating and changes with gear change. Sometimes it's noticeable at deceleration. I think my PS pump is on it's way out. Could that be it or does it sound like a tranny issue? Please advise...
2001 CL S-Type
Old 10-25-2016, 10:27 AM
Took to transmission guy and he said he thinks its the power steering pump on its last legs. Anyone experienced this noise?
Old 10-25-2016, 10:36 AM
Received 8,691 Likes on 6,705 Posts
PS pump would be bad if you just sat there and turned the wheel you would hear it whining. do you?
Old 10-25-2016, 10:39 AM
This is a different sound than the normal ps moan. It's more high-pitched and comes and goes.
Old 10-25-2016, 10:40 AM
record the sound and post it on youtube!
Old 10-25-2016, 08:05 PM
5th Gear
readerp's Avatar
My transmission guy (who was rebuilding my trans) indicated whining is also a sound the trans can make prior to quitting...
Old 11-09-2016, 11:40 AM
Eurotrash
Tosh's Avatar
I think I also have a whiny PS pump, but it's been better now that I did a few suck-n-fills of the reservoir with Honda PSF. It's also better when hot, noisier when cold.
But ON TOP of that whine I also have a bit of a very faint 'coffee grinder' sound, I guess from the torque converter...?
Old 11-09-2016, 01:14 PM
5th Gear
readerp's Avatar
Hondas and Acuras have an o-ring seal on the PS pump inlet that may leak air causing whining, especially when colder out.
Known problem, and replacement o-rings are available, cheap and easy to install.
Old 11-18-2016, 12:10 PM
YeuEmMaiMai's Avatar
does the car do it at idle? if it increases with speed it could also be a wheel bearing. I had one crap out at 90K and it sounded like it was differential whine... replaced left front and noise was gone.
Old 12-16-2016, 07:50 AM
That actually makes sense! Thanks!
Old 12-28-2016, 09:27 AM
Replaced wheel bearing and the noise is still there. Drive shaft bearing? Can CV axle shaft make whirring/whining noise through gears? Differential bearing? Anyone?
Old 12-28-2016, 10:30 AM
Eurotrash
Tosh's Avatar
Describe the noise better! Does it ever happen in Park?
Do you have fresh PS fluid and fresh ATF?
Old 12-28-2016, 12:34 PM
Never in park. Not PS Pump. New ATF. Sounds like whirring/whining possibly metal on metal. Seems to significantly quiet down in 4th or 5th. Intermediate noise that comes and goes.
Old 12-28-2016, 12:43 PM
Eurotrash
Tosh's Avatar
Could it be due a worn out motor or transmission mount?
Old 12-28-2016, 07:30 PM
I don't think so. Tested again earlier and the noise does go away when I kick it into neutral. If that helps anyone figure it out...
Old 12-29-2016, 09:33 AM
Eurotrash
Tosh's Avatar
I get a very faint "coffee grinder" type noise depending on the drivetrain loading, which I assume is the torque converter wearing out...
ob8014
11-27-2017 09:24 AM
lowther420
ILX Audio, Bluetooth, Electronics & Navigation
11-07-2016 03:31 PM
Acurian24
1G RDX Problems & Fixes
08-15-2016 10:54 AM
Realdeal89
4G TL Problems & Fixes
02-19-2016 01:11 PM
Quick Reply: Whining Noise
