Clutch going bad?
Old Dec 25, 2016 | 07:41 PM
mattcl-s's Avatar
Clutch going bad?
I think i just felt this clutch starting to slip right around 3k rpms pushed down the gas and nothing happend. The engine sounded like it was trying to accelerate but wouldnt does that mean its starting to slip? Car has 206k and im pretty sure its the oem clutch, i occasionally like to do a pull getting on the freeway like most of us do haha but other than that i am not a hard driver. Right now i have noticed no burning smell and it shifts and goes into gear like it should when taking it easy, clutch doesnt feel too spongy engages about half way up but the loss of the power has me thinking its time for a replacement. Let me know what you guys think it could be
Old Dec 25, 2016 | 08:05 PM
what gear did that happen in?
generally, clutches will slip in higher gears, particularly 5th and 6th
but yes, RPM's increasing while speed staying the same almost equals a slip
Old Dec 25, 2016 | 08:17 PM
mattcl-s's Avatar
I was in 3rd gear was around 3k and hit it and the rpms were just sorta not going past 4k there is no cel either like it was having hard time going past that
Old Dec 25, 2016 | 08:20 PM
^can you repeat it?
can it pass 4K in any other gear?
Old Dec 26, 2016 | 11:44 AM
mattcl-s's Avatar
^can you repeat it?
So i just got back from driving it around the block seemed like it went into all the gears just fine, had it in 5th going about 50mph and it felt like it was just barley making it down the street
Old Dec 26, 2016 | 12:20 PM
mattcl-s's Avatar
Probably going t go with the Luk clutch and flywheel set up going to order it off rock auto tonight pretty reasonable price on the flywheel only 195$ had a shop quote about 600$ for labor
Old Dec 27, 2016 | 01:27 PM
mattcl-s's Avatar
shop called me said the cat was clogged up which explains why it would bog down under load but never threw a CEL. there going to keep it over night just to do some more diagnostics glad I only have to spend a few hundred this time and not a thousand
Old Dec 28, 2016 | 10:34 AM
mattcl-s's Avatar
picking up the car later this evening, Im a noob to think it was a clutch problem. they guy said after the back pressure test it was reading 10 to 15psi in back pressure. I guess this thread has nothing to do with clutch now oh well live and learn
Old Dec 29, 2016 | 12:32 PM
mattcl-s's Avatar
all said and done new cat was 450$ and noticed seemed to be getting better gas mileage also, car seem to accelerate a lot smoother and quieter
Old Dec 31, 2016 | 09:26 AM
teh CL's Avatar
Never assume shit with cars. That's when shit gets expensive..
Old Jan 1, 2017 | 06:41 PM
Itr909's Avatar
9th Gear
I had the same problems with my CL. It was The catalytic converter same symptoms and everything.
Old Jan 3, 2017 | 10:40 AM
mattcl-s's Avatar
it was strange I have never experienced a catalytic converter go bad on any of my cars
Old Jan 3, 2017 | 03:06 PM
gnuts's Avatar
3.5 psi
should have just thrown an magnaflow cat on, would have been a ton cheaper. Unless they do the sniffer emissions test where you are.
