Weird Noise When Car Is Warmed Up....
Old Nov 24, 2016 | 07:14 PM
RedlineCL-S's Avatar
2001 Acura CL-S 179K. When the car is cold there is no noise. Drive for 15 minutes let it sit for a couple and start it up a weird vibrating/scraping noise is heard. Doesn't happen at idle, only between 1500-2500rpm. Noise makes in reverse and drive, but not park. Any ideas?
Old Nov 26, 2016 | 01:53 PM
Tosh's Avatar
Eurotrash
Engine or transmission mount?
Old Nov 26, 2016 | 04:34 PM
checked all already and they are fine....im on the verge of changing out the catalytic converter and see what's going on I'll post updates when I do it
Old Nov 26, 2016 | 05:17 PM
Tosh's Avatar
Eurotrash
I think you should follow the clue that noise does not happen in Park. Catalytic converter is pretty expensive to just R&R without proper diagnostic!
Old Nov 26, 2016 | 06:13 PM
Heat shield?
Old Sep 16, 2017 | 02:07 PM
cls6life's Avatar
Heat shield, or possibly an axle is on its way out. Mine made a similar noise for months then one day the axle broke and after replacing it, the noise went away. I agree it's better to diagnose then to just throw parts at it. It can be very time consuming and expensive. I hope this helps!
titan
Mar 15, 2023 11:33 AM
Stackz4G_TL
4G TL Problems & Fixes
Sep 27, 2016 09:54 AM
yassir
Sep 13, 2016 08:11 PM
pri
2G TSX Problems & Fixes
Aug 4, 2016 01:59 PM
nore03
May 4, 2016 02:10 PM
