Vibration!!!!!!!!!!!!!
Old Dec 31, 2012 | 02:38 PM
2ndgentl's Avatar
I thought I had this figured out because I have had this problem before.....long story short, took car to the track, broke driver cv axle, replaced it with AUTOZONE NEW LIFETIME WARRANTY AXLE and car was fine. I noticed that the passenger axle was starting to click on turns so I decided to replace that as well a week later, along with ALL THE BALL JOINTS on driver and passenger side just so I can get it all alligned and be done with it. Now I have a vibration under a load (acceleration). This happened to me a long time ago and it was a cv axle. So I thought a defective passenger axle....returned it and replaced it with another one....same issue. So I returned it and went with another brand from ADVANCE AUTO PARTS....SAME ISSUE. WTF?!!! 3 new cv axles and still shaking!!! So I know it CANT BE THE AXLE. I checked everything 100 times!!! The ONLY thing that is KIND OF SKEPTICAL is when I jack my car up and grab my passenger cv axle there is no movement where it plugs into the wheel hub bearing but there is a SLIGHT movement where it plugs into the half shaft. Im talking maybe 1/32" of movement in all directions. Not sure if thats normal or not.I can tell you though, I can replace a cv axle in 20 min exactly from doing it so many times. Is that a new world record? lol
Old Jan 1, 2013 | 12:04 PM
2ndgentl's Avatar
I just ordered the bearing and seal for the half shaft hoping thats what it is...somebody please respond, someone has to know something....this vibration is getting annoying.
Old Jan 2, 2013 | 05:36 PM
Sonnick's Avatar
All motor
Hmm...it only vibrates under load? Is it bad? In the steering wheel? Pedal? Both?
Old Jan 2, 2013 | 05:42 PM
2ndgentl's Avatar
I feel it through the steering wheel and the pedal....its not THAT bad but still annoying and bad enough where a passenger can feel it
Old Jan 3, 2013 | 11:01 PM
njlakeshoreg's Avatar
last week, i had the passenger side replaced, seal, axle and half shaft.......so basically the whole shit......i only had a bad vibration in the whole car under load, didnt feel it in the wheel at all...........my car was fixed from changing the whole side, went with all oem stuff
Old Jan 4, 2013 | 08:39 AM
2ndgentl's Avatar
I'll be replacing the half shaft soon and if that doesnt fix it then im going to get an OEM CV Axle even though I replaced it 3 times already
Old Jan 8, 2013 | 07:04 PM
2ndgentl's Avatar
well I just got done replacing the bearing and the seal on the half shaft and vibration is gone...perfect!
Old Feb 2, 2013 | 08:54 AM
rowman452's Avatar
Just wanted to say thanks as I am having the same exact issue. Once it warms up here I'll address it. Glad you got it fixed!! Thanks for posting this
Old Feb 8, 2013 | 06:47 PM
2ndgentl's Avatar
2ndgentl
Just wanted to mention that the vibration is still there but not as bad.....now the only thing left are the wheel bearings.....?
Old Jun 8, 2013 | 09:12 PM
turbo-cls's Avatar
How is your wobble/vibration issue? Did you replace your wheel bearings yet? Also, have you ever replaced or checked your engine mounts? I'm curious because I currently have that same wobble/vibration when driving under load/acceleration.
Old Jun 10, 2013 | 03:06 PM
AcuraJoyrider's Avatar
I've experienced what I believe is the same problem as you. However I am at an entirely different ballpark as far as remedy. When I stopped at a red light and proceeded to accelerate on my light, I would feel a sudden jolting feeling like vibrations at around 2nd gear and at sudden increase in RPMs. I was told my timing belt needed to be changed. I have a 2001 Acura cl type-s and it was at 145,000 miles that I replaced the timing belt and just for safe measures draine and refilled my transmission fluid. Right now at about 147,000 miles I haven't experienced the problem again. I hope we're talking about the same vibrations and I hope this helps. Good luck!
Old Jun 20, 2013 | 10:26 PM
Slobo7x's Avatar
I have the same problem as i go through rpms, vibration is not in the seat or steering wheel it's definitely engine related. My timing belt was changed at acura 20,000 miles ago..wonder if its engine mounts or drive belts?
Old Oct 16, 2013 | 11:38 PM
Scratcher09's Avatar
I had a 03 TL-S and it had the shudder from around 50-65 mph under load. If I let off accelerator or mashed on it the vibration would stop. Motor mounts looked like they were fine but when I pulled them out to replace all three motor mounts and both trans mounts were toast. It did not fix the vibration 100% but it made a huge difference. The vibration was barely detectable after new mounts were installed.
Old Oct 18, 2013 | 01:54 PM
thegoofster's Avatar
I just got the transmission replaced on my CLS and now I have what I believe is the same issue. The car shakes violently under acceleration and sometimes under normal driving. It never did this before the transmission was replaced I'm thinking that maybe they damaged the half shafts when they put in the new transmission . Also a new problem arose after the transmission was replaced in that car now shakes whenever it is in neutral or park . Could this all be related or am I just noticing something that was there before now because of a new transmission?
Old Nov 2, 2013 | 11:30 PM
Speedy86's Avatar
5th Gear
I'm having the same issue,I installed after market axles from advanced auto and the vibration was really bad, I got a set of oem axles and the vibration was gone for about a week then today my car started this weird clunk in the right front under acceleration everything seems tight the one thing I did notice was where the axle slides into the half shaft there is up and down movement ,is that normal??? Someone please help!!!!!!!!
Old Nov 12, 2013 | 05:29 PM
Speedy86's Avatar
5th Gear
Here's the update I'm in up state ny we have a dedicated Honda/Acura salvage yard in the area,I was having the same issue with cheap auto zone/advanced auto parts axles so I got a set of low mile used oem axles problem solved,my car is also lowerd and the oem axles made a world of difference there is no more vibration under hard acceleration or high speed
Old Nov 12, 2013 | 07:48 PM
brian6speed's Avatar
Lone Wolf
Autozone and advance axles do not have the vibration damper that oem axles have.
I thought everyone knew this by now. Just go with oem considering a new oem axle is only 150 now. I have no vibrations after replacing both axles and half shaft with new oem.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
