tune up & timing belt
Support engine , remove side mount , ac belt , ps belt , and cs pulley - you need tool to unscrew this one , impact gun is not recommended. Remove covers. Make sure cam pulley blue marks are aligned with markings on housing ( When you remove tb these pulleys shoud stay in its position and make your reinstall job easy ) Remove hydraulic tensioner , retract it and install pin through the tensioner housing . From that point you just need to carefully align marks on your new belt and reasemble. You should replace: timing belt , water pump, tensioner pulley, idler pulley and optionally: crank shaft seal, ps belt, ac belt, hydraulic tensioner - some people do this one as mandatory. No advise on plug change - that is just straight forward replacement
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
asahrts
Sep 4, 2015 05:55 PM
