Transmission Fluid Bolt
Old Apr 29, 2014 | 04:25 PM
Sweeper's Avatar
This may seem to be a silly question but I'm ready to do the drain & refill on the transmission and I can't seem to locate the drain plug. Can someone tell me the size of the nut to look for??? I've read that it takes about 3 quarts for each refill; is this pretty much the amount used? Thanks,
Old Feb 15, 2015 | 11:20 AM
waltersfield's Avatar
This DIY YouTube video on trans fluid replacement will help.
Old Feb 15, 2015 | 11:29 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
you may have the jet kit or you could have the fill bolt. if u have the jet kit, u need to remove the bolt holding it on and kinda yank the jet kit out of the orfice. it will be stuck in there real good if it has not been done in a while so for the record it pulls right out.
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
ghuns
Sep 16, 2015 04:26 PM
