tranny
Old Jan 1, 2009 | 10:14 PM
half-baked's Avatar
tranny
has anyone ever changed the tranny filter themselves? was it easy? if u took it to the shop how much did it cost?
Old Jan 3, 2009 | 07:08 PM
half-baked's Avatar
31 ppl viewed this thread n not a damn answer
Old Jan 4, 2009 | 02:32 AM
2K1CLtypeS's Avatar
Here are some instructions you can follow:
Unscrew the old filter. Put some trans fluid on the new filter's rubber gasket, then screw in and tighten the new filter. When installing the filter's steel line, make sure that the O-ring is not damaged or you'll have a leak when you first start your engine. I replaced my O-ring and coated it w/ trans fluid. Start your engine and check for leaks.
Old Jan 4, 2009 | 05:34 PM
half-baked's Avatar
thanks boss.
Pham Alvan
May 18, 2021 06:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
Pham Alvan
Mar 16, 2016 09:17 AM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
