tire wear issues! Please help!
I had got an alignment about 4 months ago on some pretty new tires. I'm riding on 19' axis seven mods with toyos. I have SPC camber kit installed on my car along with comptech springs and koni yellows on the highest perch. I recently looked and the insides of my front tires were completely worn out. The back was completely fine. What's going on? If a camber kit is not necessary, can having one hurt in anyway? I'm debating whether if I should take off the camber kit.
V-tak Yoo
when i do alignments at work Toe is the last setting because everything else changes toe. Toe will wear tires faster then camber.
i also forgot to add that most shops will not touch aftermarket kits unless they install them theirselves. or you pay more money to have a performance alignment done.
asahrts
09-04-2015 05:55 PM
