Thumping sensation..?
Old Mar 24, 2012 | 07:32 PM
oreo615's Avatar
My 2001 CL is giving me a thumping sensation after driving approx.15 minutes.I'm thinking a wheel bearing going bad or a bad tire.I put 4 new michelins on about 3 months ago..Any ideas would be appreciated..Also,the car has 145,000 miles on it..
Old Mar 24, 2012 | 07:57 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Is the noise while your rolling on a smooth road ?
sounds like a bad tire.
Bad wheel bearing will make growling humming sounds for a while before that would get to the point where you would get enough play to be making a thumping noise.
The wheel would want to lock up every once in while if it was that bad.
I don't think a wheel bearing at all.
Old Mar 25, 2012 | 04:36 AM
oreo615's Avatar
smooth road..I hate to condemn a new Michelen ..but ,I'm leaning that way..
Old Mar 25, 2012 | 03:04 PM
civicdrivr's Avatar
Bring it back to where you got the tires and have them rebalance and inspect them. While on the balance machine, they should be able to check for runout.
Id definitely suspect the tires/wheels first.
Is it speed dependent?
Old Mar 25, 2012 | 07:21 PM
oreo615's Avatar
When arriving home today..I smelled hot brake linings,so I replaced the LR brake caliper and problem solved..! Never would have suspected that with out smelling the hot brakes..
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
VoLLy
Nov 28, 2007 02:12 PM
daicacharco
Apr 26, 2007 12:12 PM
CanadianTypeS
Jul 12, 2001 08:30 PM
