Sunroof probelm, please help !
Hey Guys,
my car 2002 tl type s roughly 240K
Here is the deal. I have not used my sunroof for a year or so, today for some reason I wanted to have my sunroof open.....
The tilt worked no problem, when I tired to open the sunroof it was opening really slow, I thought It got rusted or something and that it will get better. It did not. Once opened the sunroof does not close. It will move for about 10-15cm and then stop. I tried putting wd40 on it, no luck. I figured I would do it manually with the crank in the liner. It would move the same distance and stop. I was stupid enough to push it harder and glazed the bolt. I think that it did not completely return from the tilted position and somehow got stuck when opened fully. Anyone had similar problem ??
Any help would be appreciated.
lubricate the rails and then open close a few times, problem solved
