Stuck in park with no brake lights
Old Aug 6, 2009 | 12:35 PM
mcnally215's Avatar
5th Gear
I have a 2003 Acura 3.2TL and the shifter is stuck in park and I also noticed that the brake lights aren't working? Has this happened to anyone and does anyone know how to fix or how much it will cost me? Any info would be appreciated.
Old Aug 8, 2009 | 11:40 AM
Dredd's Avatar
It is your Nuetral Saftey Switch, it is what tells the car you are stepping on the brake and so it's ok to let you shift out of park and turn on the brake lights. Part is really cheap and easy to replace. It should be down on your brake pedal.
Old Aug 8, 2009 | 02:13 PM
pits200's Avatar
Na, that isn't the problem. Its the fuse for the rear brake lights, unfortunately I can't remember which one is its. I think its a 20amp fuse on the passenger side or maybe the drivers side???
It means your rear brake lights aren't working and it's a safety mechanism which doesn't let the car move out of park until you fix the brake light problem, you can use the override method but I don't recommend that if your brake lights aren't working.
Old Aug 9, 2009 | 07:21 PM
celynka's Avatar
Sundance Gold in
Might be a fuse but rather brake switch . Its used for both brake lights and lever release
Old Sep 10, 2009 | 04:38 PM
PNJBi's Avatar
Hi,
I have the same problem on my 04 tsx. Can you tell me how this was fixed?
Thanks!
Old Sep 15, 2009 | 12:34 PM
evilstorm's Avatar
had this problem for years. Definitely was the brake fuse for me. Its labeled STOP and it also is hooked in with the horn. If your horn doesnt work either, you know what it is.
Mine was due to the low horn being shorted, so everytime i hit the horn the brake fuse would blow. Led to some pretty interesting times driving around with no brake lights...
Old Sep 16, 2009 | 02:07 PM
pits200's Avatar
Ha, I could just see someone cutting you off and you want to honk your horn so bad but you can't because you're afraid of blowing the fuse...
The frustration, I can't even imagine..
Old Sep 16, 2009 | 02:24 PM
Sal's Type S's Avatar
^^^ Yes check FUSES FIRST. Were I work at I drive a lot of different vehicles and sometimes same thing happens. You either have to hit/press the safety over ride button or turn key forward to unlock steering wheel and shifter then put in neutral then start. When you hit the brakes once its in the shop the most of the times first thing that is noticed the brake lights don't work.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
jliu6789
Sep 8, 2015 08:02 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
