Spark plug question?
Old Jul 19, 2009 | 01:38 PM
hermtm2's Avatar
Hello.
How to know whether the spark plugs are good or not? There is any issue which I've found so far. I got this CL on the last month and can't not remember the previous owner replaced the plugs or not. Here is a picture. Can you guys say something?
Thanks.
Old Jul 19, 2009 | 02:17 PM
civicdrivr's Avatar
Old Jul 19, 2009 | 02:48 PM
hermtm2's Avatar
I guess mine is normal.
Thanks.
Old Aug 10, 2009 | 02:03 PM
RideCL's Avatar
whats the best spark plug to use?
Old Aug 10, 2009 | 02:31 PM
aznboi2424's Avatar
I would use OEM spark plugs for our cars. This way you know that your plugs are good for another 105k. They are called NGK Lazer Iridiums. let me know if you need the part number.
Old Aug 11, 2009 | 02:17 PM
RideCL's Avatar
yes please i would love the part number. Ya someone told me thats what i should get. thanks for backing that up.
Old Aug 12, 2009 | 04:34 AM
aznboi2424's Avatar
NGK #IZFRK11
Honda PN: 9807B-5617W
ebay is probably cheaper then the dealer.
Old Aug 12, 2009 | 08:59 AM
SG81's Avatar
Missing My CL-S
i just ordered a set from this seller:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWNX:IT
Old Aug 14, 2009 | 12:14 AM
celynka's Avatar
Sundance Gold in
You might change them, but NGK's last forever, 100k 250k whatever mileage you pick. I got my Acura Legend running original plugs that are just perfect! ... 18 years and 260k miles!
Old Aug 14, 2009 | 04:07 AM
aznboi2424's Avatar
i would change them. just because they work, doesnt mean they work at max performance. a new plug yields more power and better MPGs
Old Aug 14, 2009 | 12:05 PM
celynka's Avatar
Sundance Gold in
Spark plugs construction is as simple as a broom stick. The only factors that affects performance is internal resistance and physical condition of terminals. Quality and craftsmanship of NGKs is superb and resistance is never affected - terminals may sometimes get burned but that still happens because of other engine issues. Simple fine sandblasting for the tips will make em brand spanking new with no reason of buying new ones!
Old Aug 14, 2009 | 02:36 PM
aznboi2424's Avatar
so you've taken your plugs out of the legend and inspected them?
Old Aug 15, 2009 | 01:25 AM
celynka's Avatar
Sundance Gold in
I ve done it twice - while changing head gaskets and basically rebuilding heads @ 170k and last fall 245k. Plugs are perfect so far
Old Aug 15, 2009 | 04:50 AM
aznboi2424's Avatar
if you say so. id rather pay the extra 45 for piece of mind. i mean it would only need to be done every 105k.
Old Aug 15, 2009 | 11:01 AM
celynka's Avatar
Sundance Gold in
I agree 100%
Old Aug 15, 2009 | 03:22 PM
aznboi2424's Avatar
but to each their own. you seem to know a lot about cars so im not going to argue with you. its like when someone does 3k synthetic oil changes lol
Old Aug 19, 2009 | 01:09 AM
hermtm2's Avatar
I am 9k on it with M-1 ext.
Old Aug 19, 2009 | 03:00 AM
aznboi2424's Avatar
i was just saying it as an example.
im gonna try 12k with mobil EP but lets not turn this into a motor oil thread.
Old Sep 17, 2009 | 12:17 AM
wichitaone's Avatar
Cheaper to just replace the set for for $40 if you go throught the trouble of taking them out. Most people don't have the necessary equipment to check spark plugs. In aircraft, where a plug can cost $50 each, they all get cleaned, gapped, and tested in a spark plug testing machine that induces a high voltage to test it.
The NKG's that I replaced at 116k miles in my CL looked great, but I prefer to run Bosch's in my vehicles. I went with the Bosch IR+4.
The Machine
Sep 24, 2018 08:27 PM
pstomps
Feb 20, 2017 03:29 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
datadr
Sep 12, 2015 09:12 PM
NSolace
Sep 3, 2015 08:14 PM
