Steering rack leak. 03 CLS
Old Oct 4, 2014 | 01:29 PM
DanZHP's Avatar
Leaked on my driveway around last week, i put in a sealer and it stopped leaking pretty much right away surprisingly. its been a week and a half and no leaks yet. i lifted it noticed the rack and where most of the lines meet just below the U joint was wet. has anyone have to fix this before? can someone let me know what solutions i have and if theres any used or new ones for sale for reasonable price. thanks peeps
Old Oct 6, 2014 | 09:14 PM
teh CL's Avatar
From what I've heard, when they start leaking they need to get replaced eventually..
Where you located? & 6 speed?
Old Oct 7, 2014 | 07:41 AM
chunky's Avatar
Hi,
I have a 2003 CL-S 6 speed. Just replaced my rack & main pressure hose. My rack was leaking for at least 3 years. I kept adding power steering fluid every few months for a quick fix until the main power hose started leaking.
Eventually you are going to have to change the rack as mentioned if you are keeping the car. It will be up to you as it is not cheap to do. I live in Montreal and the rack cost me $400. Labor will be about 4 to 5 hours, and you will need new fluid obviously and a wheel alignment. Hope this helps you with your decision.
Old Oct 7, 2014 | 11:25 AM
mshipon's Avatar
I recently thought the rack on my '03 was leaking as well. It turned out to be my power steering pump. Not as expensive as replacing the rack. You might want to have someone else check it out.
Old Oct 11, 2014 | 09:24 AM
DanZHP's Avatar
true, Hamilton Ontario. and yes its a 6 speed i just picked this car up a month ago, it had a leak before i had it cause their was already a bottle of power Steering fluid sealer in the trunk lol. fuck
Old Oct 11, 2014 | 09:28 AM
DanZHP's Avatar
Originally Posted by chunky
Hi,
thanks, where did you get the rack from?
Old Oct 11, 2014 | 09:32 AM
DanZHP's Avatar
its defiantly leaking around the pinion but i hope im wrong next time i get on the hoist. whatever i might as well replace the rack before winter. just dont wanna spend alot money im currently rebuilding my 07 Gti R.i.P.
Old Oct 14, 2014 | 07:21 AM
chunky's Avatar
My buddy did the work and he got the rack from a local parts store in St Eustache. Not sure which one. I believe that he was able to get his usual discount...
Old Oct 14, 2014 | 07:24 AM
chunky's Avatar
I was going to add that you're better off going with a new rack than a used one.
Old Oct 31, 2014 | 04:34 AM
YeuEmMaiMai's Avatar
and I would get an ACURA rack. A LOT of aftermarket parts are total crap.
Old Oct 31, 2014 | 10:36 AM
chunky's Avatar
I reconfirmed with my guy and he got me an OEM Acura rack. The cost was $460.
Old Apr 5, 2015 | 09:07 PM
mikejoyce34's Avatar
i am new here, just bought an 01 cl (type s) power steering pressure hose lesking at fitting were rubber meets metal closest to pump, need advice on how to best go about changing it and any hints from anyone who has done it, located toronto, no hoist available as yet though im working on it.
also have a low beam light out, can someone point me to replacement bulb? hid i think
also is cl same as tl in same model year with regards to this subject?
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
