Recently Bought 03 Type S 6MT Won’t Start.
Hello all, recently I bought an 03 CL Type S, 6 Speed, with 173,000 miles. When I first bought the car, it started right up, though with a bit of hesitation. Seller told me it needed a new temperature sensor as it was displaying a check engine light, causing the temp gauge to behave erratically. Put coolant in the car, began driving it home. Got gas, started up. Pulled over later as I thought it was overheating, but no coolant leaks, engine pulls strong, no strange noises, runs well when on. Once home, car will not start at all, even with a brand new starter that I just put in, without being push started. But when it starts running, it runs fine, no lights dim, it doesn’t shut off, and air blows cold. When I push the clutch in and turn the key, I will just hear a single click from the starter. What can I do?
Rule of thumb, if you are shopping for a car and it has any of the "trouble" lights lit; tell the seller to fix the car to your satisfaction before buying it. The only exception to this rule is if you are shopping for a car with a known bad engine and/or transmission; then again, the price for this type of vehicle should be pretty damned low.
bunnie_RENAMED
Jun 4, 2003 08:23 AM
