Quick Cruise Wiring Question
Real quick wiring question: I had a blown Brake relay switch that I traded out. Lost my cruise control in the process. The Cruise light comes on, but I can't set it. Fuse is fine I traded the turn signal to test and those work. relay is seeded correctly and the brake lights/shifting work. I think I've unplugged the cruise wire somewhere, or this relay I bought is not built for a car with cruise. Does anyone have a wiring pattern for where the cruise runs from the steering column to the brake relay to the fuse box. (or however it's wired)?
Also, a 2 green wire plug was loose under the steering column, I don't know what slot it goes into, nor what it does. If it's unimportant, I'll leave it alone.
cycdaniel
12-17-2019 11:58 AM
BoricuaTL
04-08-2016 02:08 PM
