Problem with j35 swap
Old Jul 1, 2018 | 10:02 AM
Soseductivesf's Avatar
So I have a cl type s 6spd which we just swapped to a j35 with rl cams. Originally we tried starting it up with an AEM EMS on an auto harness converted to the 6 speed and it will idle, but over 2500rpm it starts misfiring and putting a load on it isn’t possible. We then converted to the regular 6speed harness at the advice of some friends and tried to run the factory ecu again, but it’s doing the same thing. Over 2500 it doesn’t run right. Any ideas as to what this could be?
Old Jul 1, 2018 | 11:12 AM
Any DTC codes?
I'm sure you've done all this, since it sounds like you are surrounded with knowledgeable people and the car idles and gets up to 2500; however, you took all of the appropriate cam sensors from the front head of the 6-speed J32A2 and the pulley side crank sensor and such? Provide some details, if possible.
Hopefully, Karanx7 will see your thread and contribute. He's pretty much the only one around anymore that has the self taught in
depth knowledge to provide direction when talking electrics or AEM EMS for a 6-speed application.
Nice looking car, BTW.
Old Jul 1, 2018 | 11:34 AM
I have someone working on it. He usually builds integras and civics. No cel codes. Oem clutch and flywheel
Old Jul 1, 2018 | 11:44 AM
OK. That's a good sign there are no codes.
So, to clarify. You don't know if said sensors & cam pulley have been transferred, from the CLS6 J32A2 to the J35A3, to make it 6-speed compatable?
Since your man is familiar with integras and civics, would he have thought to do that or did you not tell him that was essential, assuming you did your research, for a J35A3 swap into a CLS6? Just curious.
Old Jul 1, 2018 | 12:21 PM
I'm sure he did his research so it may be something minor. He did switch all sensors over. We are using CLS pistons. We have the RL cams and p2r cam spacer in the j35 heads
Old Jul 1, 2018 | 12:36 PM
yes everything has been switched over
Old Jul 1, 2018 | 12:49 PM
Great! Thanks for that.
With the absence of any codes, as you say, it's probably something minor or in the rewiring connections performed so far.
When you find the issue, please update your thread.
Good Luck!
Old Jul 3, 2018 | 03:05 PM
gnuts's Avatar
3.5 psi
double check that the TPS and MAF sensors on the throttle body are in the right connector. They are easily switched and cause issues.
Old Jul 3, 2018 | 05:41 PM
That's what I think it is. Will be doing that and let you know the result
Old Jul 3, 2018 | 05:45 PM
dopeboy1's Avatar
The inconvenient truth
Where did you get the white lettering of 'toyo' and 'proxes' for your tires? I too have toyo proxes.
Old Jul 3, 2018 | 08:46 PM
gnuts's Avatar
3.5 psi
It's probably tire lettering paint. They're like sharpies. Google "tire lettering paint" and you'll find some.
Old Jul 4, 2018 | 12:31 AM
tirestickers.com
Old Jul 5, 2018 | 04:28 PM
Adam Kovach's Avatar
did you swap the cls6 toothed crank gear over or keep the automatic one on there?
Old Jul 7, 2018 | 07:54 AM
Everything was done correctly yet it still can't rev past 2300rpm with no cel. Using Luk flywheel. Could that be the problem?
Old Jul 7, 2018 | 09:43 AM
So, to recap and for posterity's sake.
Your mechanic took the following from the manual transmission J32A2 and swapped it over to the automatic transmission J35A3 to make it 6-speed compatable:
Front head camshaft pulley; TDC sensors and sub harness and front timing belt back cover plate assembly.
Crankshaft sensor sub harness; crankshaft sensor assembly; timing belt stopper plate and timing belt drive pulley (passenger side).
You've checked the TPS and MAP sensor connections, on the throttle body for proper placement, as gnuts suggested.
To this day there are no codes presently and it won't rev past 2500rpm, even after reconverting back to the OEM 6-speed harness and ECU.
Has your mechanic gone thoroughly through the connections made when the 6-speed harness was converted to the auto harness for the initial AEM EMS start-up? And then again, when it was converted back to the OEM 6-speed harness to run off the stock ECU?
Maybe, if you can get the detail from your mechanic, you can list the things you/he has tried in the past week? If there is something not covered here, list it.
The LuK DMF063 flywheel is the OEM flywheel for the CLS6. I have it on my car. Is the DMF063 the one that you are using?
With that said, why would you think using the LuK DMF would be the problem?
Especially in light of the fact that there are no codes from the crank sensors at the transmission or drive pulley side?
The only thing I have left as a suggestion is to remove the RL cams and P2r spacers and install the J32A2 cams in their place to see if THAT has any effect.
Old Jul 7, 2018 | 01:15 PM
I will have a list of things he has done. If there was a problem with the RL cams wouldn't it throw a code? I guess that's our next step. Are we supposed to use the manual harness
Old Jul 7, 2018 | 01:48 PM
Good question. Of all the people, on the 2G TL side and CL side, who have attempted this J35A3 swap, I believe you are the only one I've seen try this, initially, with RL cams.
Usually the J32A2 cams are used with the stock OEM ECU/connections and everyone has not had problems, unless there was an indicator through an errant code for a crank sensor or something.
At this point, I'm just trying to throw something out and see if it sticks.
Dude, I don't know how 'deep your pockets' are; however, all I know is something is wrong.
I would have tried to get the car running first with the OEM ECU and proven J32A2 cams before I went and started messing with the AEM EMS and chopping on harnesses. And that would have only been done with a professional tuner familiar with said AEM EMS and the CLS6 platform. Not saying your guy is not experienced with the EMS and all.
As far as using 'the manual harness' if you mean the oem harness that came stock with the car, then yes. However, when you come on here looking for help, you don't provide any details on the extent or scope of this so called 'harness conversion', so who knows WTF is going on. All we know is that you say your swapper has done his 'research' and the thing is not working.
Old Jul 7, 2018 | 04:14 PM
Perhaps the answer is as simple as the advice provided in post #4, on the link below, assuming the wiring conversion has been done correctly:
https://acurazine.com/forums/2g-cl-p...es-2-a-970534/
Good Luck!
Old Jul 10, 2018 | 09:23 AM
I have the RL cams in my J35A3 swap and haven't had a problem. No AEM but swapped over cam gears, cam sensors, crank gear sensor from 6MT. J32 to the auto J35.
My only issue that ever arose was a bad crank sensor on transmission housing. It was giving me the symptoms you describe but I had the CEL on for CKP sensor P0336. I may have spilled coolant into the sensor harness.
Old Jul 27, 2018 | 05:22 PM
OP, did you ever get the issue(s) resolved with this swap??
Old Jul 30, 2018 | 10:12 AM
Had to use the oem flywheel but it works now. But having a problem with 4-6 gears popping out
Old Jul 30, 2018 | 10:43 AM
Thanks for the response; however, I'm not quite sure what you mean when you say 'Had to use the oem flywheel...' when you stated in your third post that you where already using the 'Oem clutch and flywheel'?
You had to buy another LuK flywheel?
Old Aug 11, 2018 | 09:20 AM
Yes. I'm guessing the flywheel I bought was defective. Anyway car started up and ran but couldn't tune it with the aem fic. It was running lean. So we're putting back the em2 and hopefully can get it to run with that.
yungone501
May 8, 2016 09:47 PM
03CLSMT
Feb 5, 2012 06:42 PM
heyitsvu
Jun 17, 2011 05:23 PM
jkballin
Aug 7, 2009 12:20 PM
AcuraStyle
Mar 21, 2009 02:18 PM
