p0740 VSA, CEL, /!\
Old Jul 9, 2012 | 02:29 PM
pinoyromeo16's Avatar
8th Gear
p0740 VSA, CEL, /!\
Hi all,
It's an all too common problem with the CL. I have a 2001 CL-S.
Problem started (in sequence of events):
--A couple of months after I had a mechanic replace the transmission fluid.
--Rotated only my right side tires (my right front was bald for some reason, but my left front had the same amount of thread as the two rear tires)
--I accelerated hard a few times to get through traffic.
What happened:
VSA, CEL, /!\ light all came on.
P0740 from OBD-II reader.
Observations:
-VSA and /!\ light only comes on a few minutes after driving over 55mph on fifth gear. I drove the car on D4 over 60mph and the lights did not come on. When I shifted it to D5 the lights came on after a couple of minutes.
-Car shifts fine through all gears
-Clutch locks (observed by drop in rpm at highway speed)
-Ground wire closest to the torque converter clutch solenoid is frayed.
What I HAVE already done:
-Replaced two front tires (new)
-Replaced Torque converter clutch solenoid (with OEM part)
-Replaced Ground wire closest to the torque converter clutch solenoid
-Cleaned out EGR ports by scraping and carb cleaner (i did not replace EGR valve)
-put the bald tire back to the right front
-Replaced tranny fluid with OEM tranny fluid
What I have read may be the cause but have NOT tried:
-Knock sensor
-O2 sensor
-Wheel speed sensor
-Transmission speed sensor
-Bad Torque converter
-and of course replacing the tranny
Old Jul 11, 2012 | 07:23 PM
TexasHonda's Avatar
I just lived w/ it. It's not fixable short of removing the transmission.
good luck
TypeS860
Jan 10, 2026 11:11 AM
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
polish_pat
Sep 30, 2015 12:22 PM
hrothgar02
Sep 28, 2015 11:08 AM
