P0420 & p0430
Old Jan 26, 2010 | 07:27 AM
gnuts's Avatar
3.5 psi
P0420 & p0430
Well my car threw both these codes this weekend out of the blue.
0420: Cat efficiency below threshold
0430: Cat B2 Deteriorated
So is there any way this could be anything other then a bad cat? It is less than a year old.????
Old Jan 26, 2010 | 06:52 PM
friesm2000's Avatar
B A N N E D
was it a new OEM honda cat or some cheap-o aftermarket replacement cat???
also how is the tune on your car; a bad tune, can take a cat out quite fast also
Old Jan 27, 2010 | 07:21 AM
gnuts's Avatar
3.5 psi
it was a 2.5" in/out cat...i believe it was magnaflow, i'll have to check the bill. My mechanic said it might have just been a burp in the exhaust. So last night i gave er down a nice dry stretch of road and it cleared the code! lol....my car is telling me it missed vtech.
Old Jan 27, 2010 | 07:34 AM
ChangBanger's Avatar
J32A2//i7-930
You got aftermarket headers or Y-Pipe? When I had my Maxima (I know it's not a Honda/Acura product) I had an aftermarket Y-Pipe that was larger and had I believe a 3" collector, and pretty much all around bigger. It kept throwing P0420 codes and I forgot the other code it was throwing for the oxygen sensor right behind it. Something about the oxygen sensor faulting. I ended up replacing it and totaled it... Then I bought the CL-S.
Old Jan 27, 2010 | 05:02 PM
friesm2000's Avatar
B A N N E D
WTF is that suppose to mean
so basically you put on more of a performance cat then???, then just a "stock like" replacement
Old Jan 27, 2010 | 07:17 PM
gnuts's Avatar
3.5 psi
i have headers and 2.5"catback. i've never had that happen in almost a year with it on. Who knows what the mechanic meant. i'm glad it's gone though. That was the first time the engine light has been on since i've owned the car.
Old Jan 27, 2010 | 07:19 PM
friesm2000's Avatar
B A N N E D
a defouler will fix that light right up, when it comes back on (it will eventually)
Old Aug 26, 2010 | 12:25 PM
gnuts's Avatar
3.5 psi
well i finally got around to buying a defouler. I'm still getting the codes now and then. Going to put it on soon.
However, i just had an emissions test and a few of the readings were close to failing. My mechanic suggested new O2 sensors and i might clean out the EGR and clean my air filter. Which brand of O2 sensors are recommended?
Old Aug 26, 2010 | 09:38 PM
friesm2000's Avatar
B A N N E D
factory, or an aftermarket Denso one, which is a factory one fyi
and direct fit only, no universial bull shit either
Old Aug 27, 2010 | 08:28 AM
gnuts's Avatar
3.5 psi
thank you sir
Old Aug 28, 2010 | 02:16 PM
civicdrivr's Avatar
You can run a Bosch for the rear O2. Just dont use it for the front.
Old Aug 29, 2010 | 03:58 PM
gnuts's Avatar
3.5 psi
where's the cheapest place to get O2 sensors from? damn i didn't know they were that pricey!
Old Aug 31, 2010 | 06:52 AM
gnuts's Avatar
3.5 psi
i did some quick research online and found some really varying prices.
Rockauto: Front $57, Rear $34 (Denso)
Autopartsway.ca: Front $169, Rear $101 (Denso)
Acura of Peoria: Front $160, Rear $117 (Denso)
What's up with these prices?
Old Aug 31, 2010 | 09:21 AM
friesm2000's Avatar
B A N N E D
they seem about right, maybe a little high, but the one is cause of it being a dealer though
but that rockauto one, almost seems to good to be true though, so i would just doable check, and make sure they are not going to charge an arm and a leg for shipping and such (and since you are in canada already, could it still be cheaper to pay for the more expensive one, and not have to pay for duties and such when it arrives )
Old Aug 31, 2010 | 09:43 AM
gnuts's Avatar
3.5 psi
ya that Rockauto one threw me off. i'm thinking maybe they were universal and that's why they were cheaper? I'm going to check a local store today to see what they would charge. I'm also going to grab new spark plugs and an intake filter.
NJALLDAY57
Oct 13, 2015 08:25 AM
SiClone
Oct 1, 2015 10:22 PM
Billu99tl
Sep 13, 2015 11:30 AM
meks85
2G CL Problems & Fixes
Jun 15, 2008 12:26 AM
lcrazyaznl
1G TSX Problems & Fixes
May 17, 2008 09:41 AM
