Oil pressure sending light
Old Dec 14, 2011 | 12:46 PM
blackdog21's Avatar
3rd Gear
What is the proper voltage signal value to the oil pressure sending switch? 01 CL type S
Old Dec 14, 2011 | 07:11 PM
blackdog21's Avatar
3rd Gear
Bought a non-running 01CL-S and replaced the engine with a 75k J32A2(s type) engine. The oil light stays on. Verified oil pressure at 80+psi(mech. guage)at idle cold. Replaced sending unit with one from original engine, verified sending unit opens circuit with 60psi air applied before installing, has approx 40-50 ohms prior to pressure. Did a resistence test on on sending unit wire from it's connector to 14pin connector near firewall, measured no additional resistance. Ran engine with remote sending unit hooked to signal wire, a ground, and 60psi air pressure and light did not go out. So are there any other sensors(like vtec) commoned to the oil light. This is why I'm curious as to the voltage applied to the sending unit, if that could indicate a pcm problem.
Old Dec 24, 2011 | 01:03 PM
StreetKA's Avatar
i dont think anyone here will be able to answer you here maybe few guys like NVA-AV6 give him PM he might be able to help you
mada51589
Jan 9, 2025 04:40 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
HeloDown
Sep 8, 2015 06:51 PM
Allen_442
Sep 8, 2015 06:01 PM
