Oil Change Intervals
Old Sep 29, 2009 | 09:56 PM
  #41
aznboi2424's Avatar
you can go longer then 7.5k easily with synthetic. Maybe try 12k or something. Not sure how you drive and how good royal purple is at protection.
10W-30 is fine, you can change to 5W-20 if it bothers you though.
Old Jan 31, 2010 | 11:46 PM
  #42
KavexTrax's Avatar
CLP 01 near 98k miles, experiencing about 1 qt+ loss and I have 1000+ miles to go before the next 3750 mi change; this is starting to worry me.
Old Feb 1, 2010 | 09:43 AM
  #43
Rajca's Avatar
wham bam thank you ma'am
do u see any leaks on the ground? rear main seal is a common problem. other than that, piston rings, or valve seals
Old Feb 1, 2010 | 02:38 PM
  #44
NSXNEXT's Avatar
Originally Posted by CL-S progression 01
exactly.. if i look at the oil and it's not golden... there's wear and tear on the lubrication and or the inside of my Motor...
I love when people say that.
http://www.nordicgroup.us/oil.htm#Th...k%20Oil%20Myth
The Dark Oil Myth
Dark oil does not indicate the need for an oil change. The way modern detergent motor oil works is that minute particles of soot are suspended in the oil. These minute particles pose no danger to your engine, but they cause the oil to darken. A non-detergent oil would stay clearer than a detergent oil because all the soot would be left on the internal engine parts and would create sludge. If you never changed your oil, eventually the oil would no longer be able to suspend any more particles in the oil and sludge would form. Fortunately, by following the manufacturer's recommended oil change interval, you are changing your oil long before the oil has become saturated. Remember, a good oil should get dirty as it does it's work cleaning out the engine. The dispersant should stop all the gunk from depositing in the oil pan.
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
