No heat coming from the climate control system
Old Oct 26, 2014 | 10:50 AM
joeshed's Avatar
9th Gear
Question No heat coming from the climate control system
My 2003 CL Type S with six speed suddenly does not produce any heat in the climate control system when set on 72 degrees; in fact, only when I turn the temp setting all the way up do I get a trace of heat. No coolant leaks, and the coolant level is fine. The system tries to compensate by turning up the blower when set on Auto, so the system 'knows" that it is not hot enough inside the car, but no heat is coming through. Any ideas or suggestions?
Joe
Old Oct 26, 2014 | 11:16 AM
RedRyder's Avatar
Be a better driver
Could be a potential sign of the heater core going out. All other climate functions work okay?
Old Oct 26, 2014 | 01:29 PM
joeshed's Avatar
9th Gear
Yes everything else works OK. How do I determine if it is the heater core or not?
Old Oct 30, 2014 | 09:12 PM
Rapture's Avatar
Not sure if you've already tried this, but I had a similar problem happen. I just cranked up the heat to 90 and turned the fan speed way up, waited for it to get hot, then turn it back down to ~70 degrees and it seemed to do the trick. It should be noted that this happened on the first cold day of the year.
So it doesn't heat up at 72 even after you turn everyone on full?
Old Oct 31, 2014 | 04:24 AM
YeuEmMaiMai's Avatar
some Q's
1. is this when the car is moving or stationary?
if it is when moving only, replace your t-stat
if it is both stationary and moving then you need to lube up your actuators with a special plastic safe grease. You will have to do some disassembly of the dash to do it
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
