NO Heat in the CL
NO Heat in the CL
Hey guys,
01 CL-S Auto with 144k
I turned up the heat the other night because it gets cold here in upstate NY and noticed i dont have heat. I turn it upto 90 and air comes out the vents but its cool outside air. If i turn the AC on then it gets much colder as it should.
The motor was replaced in this car so i checked to see if the coolant line was hooked up and i see a line going into the firewall. Any ideas?
Is there only one hose going into the heater core? I didnt see anything thats disconnected. Car doesnt heat up or anything, operates just like normal. Just no hot air for the cabin, hmm
its on the firewall, passenger side. You will see a cable that comes out the firewall into the coolant hose. This cable moving back and forth is what regulates the amount of coolant. Just jiggle it and it should work after that. Hope that explains it.
