New tie rod?
Subscribe
Feb 18, 2013 | 04:09 PM
I have a small yet noticeable clunk that I can feel in the steering wheel under turning. It does it when turning either direction. I noticed it under low speeds but can also feel it when doing multiple lane changes I flick the steering wheel. I'm thinking its a tie rod but not sure if it would be the inner or outer tie rod or another component. Any suggestions? Thanks
Reply 0
Feb 19, 2013 | 11:51 PM
Tie rods are so cheap that you should just replace them all.
Check your steering rack as well.
Reply 1
Feb 21, 2013 | 01:27 PM
I have a terrible clunk not only under turning but all driving conditions. My outer tie-rods are shot so I am going to start with those. I went with Moog outers. See if that is the only steering component thats needs to be replaced.
Reply 1
Feb 22, 2013 | 02:27 PM
Yeah my buddy has access to a lift at his college(auto program) I'm going to have him take it take a look at it and see if its the rack or the tire rods. Its super light and almost unnoticeable but I'd rather fix it before it gets worse.
Reply 0
Feb 27, 2013 | 07:20 PM
Quote: I have a terrible clunk not only under turning but all driving conditions. My outer tie-rods are shot so I am going to start with those. I went with Moog outers. See if that is the only steering component thats needs to be replaced.
Also check sway bar end links
Reply 0
Mar 2, 2013 | 02:49 PM
Quote: Also check sway bar end links
Yeah - if its a sway bar issue - replaced that with Moog - its much better that the OEM
Reply 0
Subscribe
