My cars electrical system goes crazy
GOD Of ACURA-CL.COM
I'm driving down the road and all of the sudden my cd player cuts off and my speedometer goes down to zero and so does everything else my gas and all the lights on the dash light up . Next thing my ac goes out
and when i cut my car off it doesn't really want to crank so i take it up the autozone get my battery tested and they say its my altanator . Now my car just sits in the garage waiting for the dealership to open up tommrow. Has anyone else had this problem . Also I only have 41k miles on my car and i also just got headers installed could any of this effect it ? I dont want the dealership saying that i have I/h thats what caused the problem .
Originally posted by Akim711
even more strange yesterday afternoon, as i was getting out of the car i pulled the key out of the ignition and my radio kept on playing.
thats normal. It will turn off once you open the doors
"BON-AHHH-KIN-BALLS"
sounds exactly like a problem i had at 42k! My whole instrument panel would shut down sitting at a set of lights and then come back on.... also, 4/5 times starting the car... the fu#king panel would go berzerk and the D5 light would blink (after the srs and engine light would stay on. when i would put the car in gear it would slam into gear....... anyway
it took 5 seperate visits to acura for a few days each visit for them to figure out the problem. It turned out to be loose wiring behind the fuse box. go figure. good luck!
GOD Of ACURA-CL.COM
GOD Of ACURA-CL.COM
Originally posted by GoldieAlek
arent you god ? then you should know...
j/k
j/k
GOD Of ACURA-CL.COM
let me know what happens!!!!!!!!
3.7L Nitrous Breathing CL
When I did my big three for my stereo.I left the alt plug disconected.Drove for about 1hr then the same thing happened.The car drove all the way home.At evey light I kept the engine reving high hope it would not stall and make it.It made it,I shut the car off batt was dead.put plug back on jumped it then it was fine.
Check the alt plug
Check the alt plug
Whats up with RDX owners?
On the alternator.
Check the power cables running from the battery to the alternator. The alternator is on the passenger side of the motor, below the a/c compressor. You have a better shot at reaching it from below the car. If there is corrosion on the battery cables clean it up, and if the cables are crimped or corroded replace them.
Thanks .. I think I solved my problem. The metal contact on the fuel pump relay fuse was scraped nearly clean, preventing a solid connection. Replaced it and now when I jiggle it with pliers, the panel doesn't make a clicking, failure sound!
In the future, please post any problems you are having in the "Problems and Fixes" section. This way, it will be in the right thread, as well as many viewers in there that will try to help you solve the problem. But back to your problem, maybe check the fuses and make sure its not something small, because the dealership can fix your car but they will also R*pe your wallet.....
x2 and I commend him for searching before opening a new thread.
