Moisture in a headlight assembly
Old Nov 26, 2010 | 06:43 PM
hermtm2's Avatar
Hello.
I have a 2001 CL-P which has 135k on it. I found out moisture in the headlight assembly of driver's side. How to fix the problem other than replace the entire unit?
Thanks.
Old Nov 29, 2010 | 11:19 PM
brakedrift1217's Avatar
9th Gear
I have the same problems with both sides and Im thinking of baking them in the oven diassemble them, move the damn moisture with some products of cleaning headlight part, and put them back together with nice silicone all the edges to prevent the moisture. This is the better idea then buying another headlight for 300 bucks(normally). If I burn the headlight and melt them? well, then now is the time to get the new headlight :p better try lol
Old Nov 29, 2010 | 11:38 PM
hermtm2's Avatar
I don't have any problem with the headlight other than moistures. Have you ovened the headlight? I've heard that method but it sounds like advanture. I would like to the exact process.
Old Nov 30, 2010 | 02:39 PM
civicdrivr's Avatar
Check the seals on the ballast, the HID bulb cover and the seal around the high beam.
Old Feb 18, 2011 | 09:06 AM
almerricking's Avatar
leave your highs on while driving..it will get hot and dry them out. or take the bulb out (careful to not touch it) and use a hair dryer/heat gun on the front of the headlight and they will dry out. then check to make sure all the seals are good on your bulbs (and that they are twisted all the way in)
Old Feb 18, 2011 | 11:10 AM
dbramaged's Avatar
I have "baked" several headlight assemblies... 325 degrees for about 3-5 minutes is all it takes. WEAR GLOVES and be sure not destroy the tabs that hold the lens to the housing. Several people bend them with the plastic being very hot and they stay that way or will snap when they cool down.
Old Feb 22, 2011 | 02:08 PM
aznboi2424's Avatar
I do not recommend driving around with high beams on just to dry out the housing.
What I do is take the high beam bulb out and then drive around. It will dry out after a few days from the heat of the engine.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
