Memory Seats: Need Resetting Help
Old May 29, 2009 | 05:13 PM
ChineseGuyinthe415's Avatar
Hey guys,
A while back my car was in the shop to get repaired for a rear-end accident and when I got the car back, the memory seats doesn't work anymore.
I tried to do a search on "memory +seats, seat, repair, fix" and it took me to all the homepage threads which was weird.
Can someone please help me out with this? I tried looking in the owners manual but couldn't find anything on how to reset it.
Old May 29, 2009 | 05:18 PM
evan03CL's Avatar
Wait...I just blacked out
you mean it's just not set for your original setting? or it doesnt work at all?
Old May 29, 2009 | 05:19 PM
not working at all. I press the buttons and no beep. Just see the 2 green dots, red memory dot isn't even there anymore
Old May 29, 2009 | 05:53 PM
aznboi2424's Avatar
theres a red dot? you mean the red memo button?
try checking your fuses. there are some fuses for the memory seats too.
you adjust the seat to how you want it then press the red "memo" button. The 2 green buttons for memory1 and memory 2 should start blinking, asking you what you want to set that position as.
Old May 29, 2009 | 05:58 PM
yea i know how to work the memory seats. Just when I push the buttons nothing happens Where at those fuses and how do I know if its bad? I think there's a fuse box under near the pedals? and one under the hood i think?
Old May 29, 2009 | 06:10 PM
aznboi2424's Avatar
i dont think the ones for the memory seats are under the hood. there are 2 more fuse boxes. one on the driver's side and on the passenger side. you'll have to open the door to access them. pull open the panel and there is a list on the inside of the panel telling you what each fuse is for.
Old May 29, 2009 | 09:25 PM
civicdrivr's Avatar
Have you set the position for the memory seating since you got the car back?
Alot of body shops disconnect the battery. In doing so your memory seats lose the settings. Just set it again. Hit the red button, then his the 1 or the 2.
Old May 29, 2009 | 09:44 PM
aznboi2424's Avatar
he said he knows how to operate it, but there is no response from either of the 3 buttons.
did they replace the driver's door?
Old May 29, 2009 | 10:38 PM
Nope didn't replace the drivers door. The buttons just does not respond AT ALL. Is there like a combination that I can push to reset the memory seats? I don't even know if that's possible. Just like how we reset the CEL by holding the reset+whatever button on the dash and turning the key.
Old May 29, 2009 | 11:03 PM
nf3d0149ab's Avatar
I have never used my seat memory.
Old May 29, 2009 | 11:23 PM
civicdrivr's Avatar
Even if you hold the memory button it doesnt do anything?
Old May 30, 2009 | 01:05 AM
aznboi2424's Avatar
I would really check the fuses first.
Old May 30, 2009 | 11:35 AM
push button, nothing happens. if its the fuse, then just replace I suppose? or can I just take it out and pop it back in? haha
Old May 30, 2009 | 02:08 PM
civicdrivr's Avatar
I dont have a scanner at my house so bear with me.
Displaying Diagnostic Trouble Code:
1. Turn the ignition off.
2. Press are three buttons at the same time.
3. Turn ignition to ON (II) and wait at least 1 second, then release the buttons.
4. After one second, the position button indicators will blink to show the DTC.
*If there is no DTC stored, the indicators blink only once.
*If there is a DTC stored, the first digit is indicated by the number of long (1 second) blinks, and the second is idicated by the number of short (.26 second) blinks. There will be a 3 second break between each DTC if there are multiple codes.
To exit DTC indication, turn ignition off.
Post back what you see. You'll see 3 long blinks, then either 1, 2, 3, or 7 quick blinks.
Old May 30, 2009 | 07:50 PM
aznboi2424's Avatar
^ what is that for? looks familiar but havent seen that in a very long time
if the fuse is blown, then you'll need a new one of the same amp rating. you'll have to pull it out to see if its blown. you hold it to the light and see if the arc inside the fuse is disconnected.
the fuse boxes that the memory seats are either in the driver's side or passengers side.
Old May 30, 2009 | 10:14 PM
civicdrivr's Avatar
You run that test on the memory seat switch. It will tell you if there is an issue with any other components, be it the speed sensor wiring, the power seat controller or the power mirror controller.
Old May 30, 2009 | 10:16 PM
aznboi2424's Avatar
hmm very nice. it would be interesting to see what the OP comes up with. but if its a power issue (IE. blown fuse) then he wont get any lights to go off. but its worth a shot.
Old May 30, 2009 | 10:39 PM
civicdrivr's Avatar
Yea, but if it isnt a blown fuse the lights wont go on if he isnt in that mode anyway, since he doesnt have the memory set.
Jul 16, 2017 07:33 AM
nj2pa2nc
Aug 19, 2016 06:18 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
