May not be a problem
Shoveling snow off my driveway Sunday, I started the CL to warm and defrost it. Not too long after I started it, the rpms started to vary (like someone was giving it throttle up to about 2000 then back down). It did seem like the RPMs did not go as high as the car got warmer. No code lights were lit. I feel the car is probably fine, but this seemed odd.
You'll need to replace the idle control valve right below the throttle body. I had the same problem as you did.
More Information for STANDARD MOTOR PRODUCTS AC229T
Oldsman71 (01-12-2015)
Thanks for this input. Will definitely check it out when I get some time. Life has thrown me a curve this week, and I'm having to deal with aging parent issues.
Oldsman71 (01-17-2015)
Common problem with the Idle Air Control Valve. I would think about a replacement due to not wanting to break down somewhere out on a highway far from home. Just a thought. Some members have cleaned them and all was good. Some others still have problems after cleaning.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
