Low Beam Headlight Out
Old Jul 26, 2009 | 03:31 PM
sloojoe's Avatar
Need help troubleshooting drivers side low beam headlight. It was working intermittantly, but now its completely out. I checked the fuse and it is not blown. Now what? I read about a possible bad ballast, but how do I diagnose that as the culprit? Should I take the working headlight and put it in the drivers side or is there an easier way. What are the next steps I should take to figure out if its the headlight or something else?
joe
Old Jul 26, 2009 | 03:57 PM
invisiblewar's Avatar
an asshole from florida
try the other bulb and see if that works, if not...time for a new ballast
Old Jul 27, 2009 | 02:33 AM
dave586270's Avatar
Chamorro
Yeah, swapping the bulbs is the quickest way to find out if its the bulb or the ballast.
Old Jul 27, 2009 | 10:09 AM
implicit's Avatar
eh
And do your research, I seem to recall there being a grounding issue that can cause this ... you'll want to look into that before buying a new ballast.
Old Jul 28, 2009 | 08:34 AM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
When mine was flickering and not staying on I bought new bulbs and that solved the problem for about 2 days.. 90% it is the ballast, search some junk yards u can find one for $100-$150, DLR is gonna want $300+ for just the part and $600 for part and install!
Old Jul 28, 2009 | 10:51 PM
dave586270's Avatar
Chamorro
Yeah new ballasts are not cheap. I thought mine was going but i got lucky and it was just the bulbs. There is a great DIY to replace the ballasts and you can get kits cheap. There is a group buy in the BM for $60 for a full kit. Little modding to the housings and you've got all new lights!
DIY: https://acurazine.com/forums/2g-cl-2001-2003-50/diy-ballast-oem-aftermarket-conversion-716617/
Group Buy: https://acurazine.com/forums/sponsored-sales-group-buys-10/hid-special-%2460-shipped-acurazine-members-723872/
Old Jul 29, 2009 | 02:39 PM
sloojoe's Avatar
Thanks everyone.
Old Jul 30, 2009 | 03:57 PM
dave586270's Avatar
Chamorro
No problem man. Let us know if you have any questions. I've got a DIY for clearing the headlights that will show you how to get the housing off the car so you can work on the ballasts with the DIY link i gave ya.
Old Jan 25, 2010 | 10:46 PM
acurabat's Avatar
4th Gear
Hey Dave586270,
Getting ready to check my low beam with a new one since it goes on then off. May be short but to check, I tried to use a T20 bit. It did not word because it appears I need a bit with a hole in the middle. Is this true? Where do I get this? Dealer?
Thanks Jeff aka Acurabat
Old Jan 26, 2010 | 01:03 AM
darketernal's Avatar
i defeated those darn security torx with a flathead screw driver that fit in the screw. push down and turn and those babies will be out in no time
Old Jan 26, 2010 | 12:09 PM
dave586270's Avatar
Chamorro
Originally Posted by acurabat
Hey Dave586270,
A flat head can work, thats what I did the first time I took off my bulb covers, haha. But what you need is a torque bit. Plus the flat-head method can strip that torque screw if you do it a few times then your screwed. Just go to any tool shop, i went to the True Value down the street and picked up a torque set with like 20 bits for $5. Then you can do it right from there on. GL, if you have any other questions feel free.
Old Jan 26, 2010 | 02:58 PM
civicdrivr's Avatar
Theres a dimple in the middle of the screw though. Ive not seen any Torq bits with the dimple. I just took the dremel and put a slot into the screw head. Now I can use a flat head.
Old Jan 26, 2010 | 04:22 PM
o1s's Avatar
o1s
i drilled the nipple out of the bolt head on mine.
Old Jan 27, 2010 | 02:04 AM
dave586270's Avatar
Chamorro
Haha, all th sets i've seen have the the torque bits with the holes and without in the same set. Glad you got it though!
Old Jun 21, 2010 | 05:14 PM
kuhndogny's Avatar
So what about the "danger" warning stating something like "danger 25,000 volts can kill you", it there that much voltage there to be aware of?
Old Jun 21, 2010 | 07:25 PM
civicdrivr's Avatar
Yea, make sure the lights are off when unplug them.
Disconnect the ballast too for extra safety.
Old Jun 21, 2010 | 09:56 PM
sayfulhaqq's Avatar
I have the same situation, but the light just went out and there is no flickering. The fuse was blown, replaced , blew out again, so mine is def a ballast issue?
Old Feb 17, 2015 | 01:33 PM
stoughton's Avatar
low beam right side out.
Guy came in with right side low beam out. He had replace the bulb and that didn't help. I checked power at the bulb and has not power going to it. From reading post it sounds like balist. No bolwn fuses and good relays. Also I see that its said to replace the system with a new kit as its better and cheaper to do so. Any help with this would be great. Thanks.
Old Feb 17, 2015 | 01:35 PM
^ The Retrofit Source Inc
the moto3five kits are awesome
blacktsxwagon
Oct 27, 2015 10:12 PM
rockyboy
Sep 29, 2015 12:05 AM
h22lude
Sep 27, 2015 06:22 PM
ceb
ILX
Sep 27, 2015 10:56 AM
AmplifiedDetails
Sep 24, 2015 02:55 PM
