Leaking Coolant Help!!!
Old May 18, 2009 | 02:08 AM
RTizzo's Avatar
I drove 2-3 miles uphill until I reached my destination. I come out and see coolant leaking on the ground. Pop the hood and i see the coolant reservoir tank overflowing. Turned off the car for a couple minutes. Started it again and it sucked all the juice out of the reservoir tank. Anyone have any ideas what the problem is?
Old May 18, 2009 | 03:07 PM
camaroracer016's Avatar
no visable leaks other than the resivoir overflowing? Could be thermostat, w/p, or a number of things.
Old May 18, 2009 | 04:50 PM
aznboi2424's Avatar
how was the temp guage inside the car?
im thinking it might be the thermostat.
Old May 18, 2009 | 09:17 PM
YeuEmMaiMai's Avatar
it is definately one of these 4:
1. rad cap failed
2. t-stat stuck closed
3. rad plugged
4. head gasket
most likely 1 or 2 because if it is 3, you're screwed, if it is 4 you might want to lube up and bend over.
Old May 19, 2009 | 02:30 AM
RTizzo's Avatar
The temp gauge was at normal level and the only leak I saw was from the reservoir. These past days ive been driving normal conditions and everything seems fine. I hope my car is not about to die. Just passed the 191k mark.
Old May 19, 2009 | 02:34 AM
aznboi2424's Avatar
change the radiator cap and the thermostat.
i heard the radiator cap should be checked every time you do a coolant change.
changing those 2 are easy and inexpensive. i havent heard many major problems with the J32A2 engines.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
